- To:
- Subject: Re: [cgal-discuss] Map Overlay implementation
- Date: Wed, 26 Nov 2014 19:17:42 +0200
Hi Luca,
The plane-sweep algorithm (a.k.a.
sweep-line) implementation can be viewed as a framework with callbacks
to predetermined functions of a visitor. The framework (in general) is implemented as a class template, and the visitor is one of the template parameters of the framework.Specific operations, such as aggregate insertion, batched decomposition, and map overlay are implemented using a dedicated visitor, which is plugged into the framework class template.
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
_/
On Wed, Nov 26, 2014 at 6:07 PM, lukkio <> wrote:
I've looked both the code and the book too.
I've understood that:
1. The overlay methods rely on sweep line, till here nothing new to me.
2. The sweep line it self rely is implemented by a design pattern "Visitor"
(this is interesting)
In this case i don't understand how the real visitor is implemented for
iterate (i suppose) along the elements on the sweep line and the performs
some operation on such element.
So the question is... how is implemented the visitor for the sweep line?
Lukkio
View this message in context: http://cgal-discuss.949826.n4.nabble.com/Map-Overlay-implementation-tp4660171p4660176.html
- [cgal-discuss] Map Overlay implementation, lukkio, 11/26/2014
- Re: [cgal-discuss] Map Overlay implementation, Efi Fogel, 11/26/2014
- Re: [cgal-discuss] Map Overlay implementation, lukkio, 11/26/2014
