- To:
- Subject: Re: [cgal-discuss] MinGW issues
- Date: Fri, 28 Nov 2014 17:45:21 +0100
Le Friday 28 November 2014 16:24:43 xantares 09 a écrit :
> > From:
> > To:
> > Date: Thu, 27 Nov 2014 13:18:36 +0100
> > Le Wednesday 26 November 2014 14:59:46 xantares 09 a écrit :
> > > Hello,
> > > I've got issues cross-compiling CGAL 4.5 with MinGW64 (mingw-gcc 4.9.1)
> > > from
> > > linux (x86_64 host).
> > Can you post an email explaining how you did that with CMake? What
> > toolchain file have you used, and how have you solved all the issue of
> > system introspection?
> Will these two patches be included in the next release ?
The first patch on <CGAL/sse2.h> is being integrated in the future CGAL-4.5.1
bug-fix release, and in our 'master' Git branch. The second patch on the
CMake
scripts is more questionable. We are currently redoing all our CMake scripts,
and your patch is probably not worth being integrated in 'master'.
As for the CGAL-4.5 branch, I want to test your MinGW setup before modifying
the CMake scripts, but I have not had the time so far.
> Do you have a public repo ?
Unfortunately, not yet. There is an ongoing work to publish our Git
repository
on Github. I hope that it will be finished during the first trimester of 2015.
Laurent Rineau, PhD
- [cgal-discuss] MinGW issues, xantares 09, 11/26/2014
- Re: [cgal-discuss] MinGW issues, Laurent Rineau (CGAL/GeometryFactory), 11/26/2014
- RE: [cgal-discuss] MinGW issues, xantares 09, 11/27/2014
- Re: [cgal-discuss] MinGW issues, Laurent Rineau (CGAL/GeometryFactory), 11/27/2014
- RE: [cgal-discuss] MinGW issues, xantares 09, 11/28/2014
- Re: [cgal-discuss] MinGW issues, Laurent Rineau (CGAL/GeometryFactory), 11/28/2014
- RE: [cgal-discuss] MinGW issues, xantares 09, 11/29/2014
