Re: [cgal-discuss] Computing the volume of the intersection of two convex polytopes
- To:
- Subject: Re: [cgal-discuss] Computing the volume of the intersection of two convex polytopes
- Date: Tue, 2 Dec 2014 13:51:20 +0100
Thanks a lot Sebastien :)
cheers,On Tue, Dec 2, 2014 at 1:37 PM, Sebastien Loriot (GeometryFactory) <> wrote:
On 11/26/2014 11:52 AM, Costas Tsirogiannis wrote:
Greetings,
Hi Costas,You can use the duality.
I have been looking in the CGAL manual to try to find possible ways that
I could compute for two convex polytopes the volume value of their
intersection. From what I can understand, the highest dimension that I
can currently do this is three; express these polytopes as Nef
polyhedra, do the intersection operation and convert them back to a
polyhedron. I would like to ask if there is any other (faster) way to do
this for three dimensions, and of course, if the current version
supports this computation for higher dimension polytopes.
Have a look at this thread:
http://cgal-discuss.949826.n4.nabble.com/How-to-efficiently-compute-intersection-of-half-planes-td4657312.html
Sebastien.
thanks in advance,
--Constantinos
- Re: [cgal-discuss] Computing the volume of the intersection of two convex polytopes, Sebastien Loriot (GeometryFactory), 12/02/2014
- Re: [cgal-discuss] Computing the volume of the intersection of two convex polytopes, Costas Tsirogiannis, 12/02/2014
