cgal-discuss - Re: [cgal-discuss] build error when reconstruction surface without normals
  • To:
  • Subject: Re: [cgal-discuss] build error when reconstruction surface without normals
  • Date: Thu, 04 Dec 2014 14:53:57 +0100
Dear deeFisher,
This looks like a compilation error in C++ templates. The code snippet is too short to guess where is the error.
Please post your complete code to let us try to compile it.
It also a good idea to specify your platform and compiler.
PS: "pmap" stands for Boost Property Map, which is a generalization of STL maps. See http://doc.cgal.org/latest/Property_map/index.html
Best regards,
Laurent Saboret
Le 02/12/2014 14:15, deeFisher a écrit :
I'm getting a similar error with cgal 4.5... whilst trying to carry out a
surface reconstruction without any external .xyz file. I'm trying to remesh
an existing polyhedron basically.
with the Exact_predicates_inexact_constructions_kernel Kernel;
i'm trying to:
-get the points (kernel::point_3) from a polyhedron,
-work out all the vertex normals (kernel::vector_3),
-combine them into a std::vector<Point_with_normal> (below)
-then call the Poisson_reconstruction_function function (below)
typedef CGAL::Point_with_normal_3<Kernel> Point_with_normal;
typedef std::vector<Point_with_normal> PointList;
PointList PVpoints;
for (int i = 0; i < mPoints.size(); i++){
Point_with_normal p(mPoints[i], vNormals[i]);
PVpoints.push_back(p);
Poisson_reconstruction_function function(PVpoints.begin(),
PVpoints.end(),
CGAL::make_normal_of_point_with_normal_pmap(PVpoints.begin()));
I don't fully understand the whole pmap thing... but the above code shows
the only place i've used the function in my program... the errors i get are
below:
Error 4 error C2039: 'R' : is not a member of
'std::back_insert_iterator<PointList>' c:\Program Files
(x86)\CGAL-4.5-beta1\include\CGAL\Kernel_traits.h 33 1
embody_mesh
Error 5 error C2146: syntax error : missing ';' before identifier
'Kernel'
c:\Program Files (x86)\CGAL-4.5-beta1\include\CGAL\Kernel_traits.h 33
1
embody_mesh
Error 6 error C4430: missing type specifier - int assumed. Note: C++
does
not support default-int c:\Program Files
embody_mesh
Error 7 error C2208:
'CGAL::Exact_predicates_inexact_constructions_kernel' :
no members defined using this type c:\Program Files
embody_mesh
Error 8 error C1903: unable to recover from previous error(s);
stopping
compilation c:\Program Files
embody_mesh
any ideas?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/build-error-when-reconstruction-surface-without-normals-tp4658740p4660205.html
