- To:
- Subject: Re: [cgal-discuss] CGAL_CreateSingleSourceCGALProgram
- Date: Fri, 5 Dec 2014 00:35:33 -0800
> On Dec 5, 2014, at 12:27 AM, Laurent Rineau (CGAL/GeometryFactory)
> wrote:
>> If not, what should I use instead?
> Actually, that CMake macro has been modified, since its creation, and it is
> compatible with multiple source files. You can use for example:
> create_single_source_cgal_program( "src/cdt-docopt.cpp" "src/cdt-aux.cpp")
> The name of the target is chosen after the name of the first source file.
Wow, awesome!
That worked so easily. I just did:
"src/docopt/docopt.cpp”)
And it handled docopt.cpp plus the 4 header files in the same directory.
Thank you very much Laurent!
> Laurent Rineau, PhD
> R&D Engineer at GeometryFactory http://www.geometryfactory.com/
> Release Manager of the CGAL Project http://www.cgal.org/
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
- [cgal-discuss] CGAL_CreateSingleSourceCGALProgram, Adam Getchell, 12/05/2014
- Re: [cgal-discuss] CGAL_CreateSingleSourceCGALProgram, Guillaume Damiand, 12/05/2014
- Re: [cgal-discuss] CGAL_CreateSingleSourceCGALProgram, Laurent Rineau (CGAL/GeometryFactory), 12/05/2014
- Re: [cgal-discuss] CGAL_CreateSingleSourceCGALProgram, Adam Getchell, 12/05/2014
