- To:
- Subject: Re: [cgal-discuss] CGAL with newer Core?
- Date: Tue, 09 Dec 2014 12:55:37 +0100
Hi Peter,
have you tried a new version? Is the error fixed in there? Note that you don't have to use the shipped version of Core.
We had no plans to update the version, also because we have not been aware of problems so far. Can you elaborate in which situation with CGAL the error occurs?
eriC
On 12/9/14 12:23, Peter Palfrader wrote:
Hi!
CGAL 4.5 ships with and uses its own version (1.7) of the Core library. I
have run into what I believe is an issue with that version of Core and that
just might be fixed in a newer Core release [1].
Is anybody working on bringing a newer version of the Core library to CGAL?
Are there any documents already describing using a newer version of Core with
CGAL?
Cheers,
Peter
1: I get the following assertion error:
/usr/include/CGAL/CORE/BigFloat.h:249: int CORE::BigFloat::sign() const: Assertion
`(err() == 0 && m() == 0) || !(isZeroIn())' failed.
- [cgal-discuss] CGAL with newer Core?, Peter Palfrader, 12/09/2014
- Re: [cgal-discuss] CGAL with newer Core?, Eric Berberich, 12/09/2014
- Re: [cgal-discuss] CGAL with newer Core?, Peter Palfrader, 12/10/2014
