- To:
- Subject: Re: [cgal-discuss] Surface mesh simplification placement policies
- Date: Fri, 12 Dec 2014 13:43:13 +0100
Dear Qianqian,
Attached you find a modified version of your file.
I've put comments with AF: where I changed something.
Concerning your other question, I am not aware of
mesh simplification that can guarantee that there
are no self intersections.
Note that in CGAL we have a package to check if
there are self intersections, so you could make
a copy of the mesh, run the simplification,
test if everything is ok, and only then replace
the mesh. This admittedly is far from elegant.
Best regards,
Andreas
On 03/12/2014 18:45, Qianqian Fang wrote:
On 11/26/2014 03:11 AM, Andreas Fabri wrote:
Dear Qianqian,
We cleaned up the mechanism to mark edges as non-removable.
Please have a look at the example in the manual:
http://doc.cgal.org/latest/Surface_mesh_simplification/index.html#title14
hi Andreas
thanks for your reply. I did notice the new implementation when I read the
updated documentation. However, I don't think this addresses what I
hope to achieve, i.e. using both Midpoint and LT placement policies in a
single unit.
Can you, or one of your colleagues, point me to a sample code where
the LT placement is used? I'd like to see how to combine this with
the Midpoint code sample.
Also, can any of you comment on the second question I had?
My second question: using the Midpoint placement method, a
simplified surface often presents self-intersecting elements. I am
wondering if the LT placement, or any other approaches that can
prevent the surface elements from intersecting after decimation?
thanks
Qianqian
Best regards,
Andreas
On 24/11/2014 23:09, Qianqian Fang wrote:
Dear list:
I have a slightly modified surface mesh simplification code, with
the previous help from Fernando Cacciola, compiled for my meshing
toolbox "iso2mesh". I just made some changes to this code to
add the support for the default Lindstrom Turk placement policy
in addition to the Midpoint placement, allowing them to be selected
through the command options. However, my modified code no
longer compiles.
My code change can be found at
https://sourceforge.net/p/iso2mesh/code/456
and the full sample unit can be browsed here:
https://sourceforge.net/p/iso2mesh/code/HEAD/tree/trunk/cgalsimp2/edge_collapse_enriched_polyhedron.cpp
(the previous changes suggested by Fernando was to
fix the edges on the boundary when a surface is open)
the compilation errors are attached.
Perhaps there is something simple that I have overlooked, can someone
tell me how can I get this to work?
thanks
Qianqian
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
//= CGAL Mesh Simplification Code Modified for iso2mesh toolbox =
//Modified by Qianqian Fang <fangq at nmr.mgh.harvard.edu>
//with help from Fernando Cacciola <fernando.cacciola at geometryfactory.com>
//Date: 2008/03
#include <iostream>
#include <fstream>
#include <CGAL/Simple_cartesian.h>
#include <CGAL/Polyhedron_3.h>
#include <CGAL/IO/Polyhedron_iostream.h>
// Adaptor for Polyhedron_3
#include <CGAL/boost/graph/graph_traits_Polyhedron_3.h>// AF: added
//#include <CGAL/Surface_mesh_simplification/HalfedgeGraph_Polyhedron_3.h> //
AF: removed
// Simplification function
#include <CGAL/Surface_mesh_simplification/edge_collapse.h>
// Extended polyhedron items which include an id() field
#include <CGAL/Polyhedron_items_with_id_3.h>
// Stop-condition policy
#include
<CGAL/Surface_mesh_simplification/Policies/Edge_collapse/Count_ratio_stop_predicate.h>
// Default cost and placement policies
#include
<CGAL/Surface_mesh_simplification/Policies/Edge_collapse/LindstromTurk_placement.h>
// Non-default cost and placement policies
#include
<CGAL/Surface_mesh_simplification/Policies/Edge_collapse/Midpoint_and_length.h>
typedef CGAL::Simple_cartesian<double> Kernel;
typedef Kernel::Point_3 Point ;
// Setup an enriched polyhedron type which stores an id() field in the items
typedef CGAL::Polyhedron_3<Kernel,CGAL::Polyhedron_items_with_id_3> Surface;
typedef Surface::Halfedge_handle Halfedge_handle ;
namespace SMS = CGAL::Surface_mesh_simplification ;
typedef SMS::Edge_profile<Surface> Profile ;
// The following is a Visitor that keeps track of the simplification process.
// In this example the progress is printed real-time and a few statistics are
// recorded (and printed in the end).
struct Visitor
Visitor()
: collected(0)
, processed(0)
, collapsed(0)
, non_collapsable(0)
, cost_uncomputable(0)
, placement_uncomputable(0)
// Called on algorithm entry
void OnStarted( Surface& ) {}
// Called on algorithm exit
void OnFinished ( Surface& ) { std::cerr << "\n" << std::flush ; }
// Called when the stop condition returned true
void OnStopConditionReached( Profile const& ) {}
// Called during the collecting phase for each edge collected.
void OnCollected( Profile const&, boost::optional<double> const& )
++ collected ;
// std::cerr << "\rEdges collected: " << collected << std::flush ;
// Called during the processing phase for each edge selected.
// If cost is absent the edge won't be collapsed.
void OnSelected(Profile const&
,boost::optional<double> cost
,std::size_t initial
,std::size_t current
++ processed ;
if ( !cost )
++ cost_uncomputable ;
if ( current == initial )
std::cerr << "\r" << current << std::flush ;
// Called during the processing phase for each edge being collapsed.
// If placement is absent the edge is left uncollapsed.
void OnCollapsing(Profile const&
,boost::optional<Point> placement
if ( placement )
++ collapsed;
else ++ placement_uncomputable ;
// Called for each edge which failed the so called link-condition,
// that is, which cannot be collapsed because doing so would
// turn the surface into a non-manifold.
void OnNonCollapsable( Profile const& )
++ non_collapsable;
// AF: added
void OnCollapsed(Profile const&, Surface::Vertex_handle)
std::size_t collected
, processed
, collapsed
, non_collapsable
, cost_uncomputable
, placement_uncomputable ;
template<class GetCost_>
struct Cost_with_fixed_edges : GetCost_
typedef GetCost_ GetCost ;
// typedef typename GetCost::Profile Profile ; // AF Profile no longer
nested type
//typedef typename GetCost::Point Point ; // AF
//typedef typename GetCost::result_type result_type ; // AF
template <typename Profile, typename T> // AF: make it a template
boost::optional<typename Profile::FT>
operator()(
Profile const& aProfile,
T const& aPlacement ) const // replace result_type
if ( aProfile.border_edges().size() > 0 )
return boost::none ;
else
return this->GetCost::operator()(aProfile, aPlacement);
typedef Cost_with_fixed_edges< SMS::Edge_length_cost<Surface> > My_cost ;
typedef Cost_with_fixed_edges< SMS::LindstromTurk_cost<Surface> > LT_cost ;
int main( int argc, char** argv )
Surface surface;
float maxface=0.1;
int defaultpolicy=0;
std::ifstream is(argv[1]) ; is >> surface ;
if(argc>2) maxface=atof(argv[2]);
if(maxface<0){
defaultpolicy=1;
maxface=-maxface;
printf("max face ratio=%f\n",maxface);
// The items in this polyhedron have an "id()" field
// which the default index maps used in the algorithm
// need to get the index of a vertex/edge.
// However, the Polyhedron_3 class doesn't assign any value to
// this id(), so we must do it here:
int index = 0 ;
for( Surface::Halfedge_iterator eb = surface.halfedges_begin()
, ee = surface.halfedges_end()
; eb != ee
; ++ eb
eb->id() = index++;
printf("edge index number %d\n",index);
index = 0 ;
for( Surface::Vertex_iterator vb = surface.vertices_begin()
, ve = surface.vertices_end()
; vb != ve
; ++ vb
vb->id() = index++;
// In this example, the simplification stops when the number of undirected
edges
// drops below 10% of the initial count
SMS::Count_ratio_stop_predicate<Surface> stop(maxface);
Visitor vis ;
// The index maps are not explicitelty passed as in the previous
// example because the surface items have a proper id() field.
// On the other hand, we pass here explicit cost and placement
// function which differ from the default policies, ommited in
// the previous example.
printf("mesh simplificaton in progress ...\n");
int r;
if(defaultpolicy)
r = SMS::edge_collapse
(surface
,stop
,CGAL::vertex_index_map(get(CGAL::vertex_external_index,surface))
// AF was boost::get
.edge_index_map (get(CGAL::edge_external_index ,surface))
.get_cost (LT_cost())
.get_placement (SMS::LindstromTurk_placement<Surface>())
.visitor(vis) // AF: not a pointer
else
(surface
,stop
.get_cost (My_cost())
.get_placement (SMS::Midpoint_placement<Surface>())
.visitor(vis)
std::cout << "\nEdges collected: " << vis.collected
<< "\nEdges proccessed: " << vis.processed
<< "\nEdges collapsed: " << vis.collapsed
<< std::endl
<< "\nEdges not collapsed due to topological constrians: "
<< vis.non_collapsable
<< "\nEdge not collapsed due to cost computation constrians: "
<< vis.cost_uncomputable
<< "\nEdge not collapsed due to placement computation constrians:
<< vis.placement_uncomputable
<< std::endl ;
std::cout << "\nFinished...\n" << r << " edges removed.\n"
<< (surface.size_of_halfedges()/2) << " final edges.\n" ;
std::ofstream os( argc > 3 ? argv[3] : "out.off" ) ; os << surface ;
return 0 ;
// EOF //
- Re: [cgal-discuss] Surface mesh simplification placement policies, Qianqian Fang, 12/03/2014
- Re: [cgal-discuss] Surface mesh simplification placement policies, Andreas Fabri, 12/12/2014
