cgal-discuss - Re: [cgal-discuss] CGAL segfaults on g++ 4.8.1
  • To:
  • Subject: Re: [cgal-discuss] CGAL segfaults on g++ 4.8.1
  • Date: Mon, 12 Jan 2015 10:45:12 +0100
On 01/12/2015 10:31 AM, Etienne Vouga wrote:
Although 4.8 is listed as a supported platform, I discovered that due to a
bug in gcc it is unsafe to use cgal with g++ 4.8.1: everything compiles but
you get random segfaults when building AABB trees.
I switched to g++ 4.7 which resolved the issue.
While I fully understand this is the fault of GCC, and not CGAL, many users
on Ubuntu 13.10 will have 4.8.1 installed as their default compiler. Please
consider adding a note on the CGAL web site or install documentation so that
they may avoid this pitfall.
In your case, were you using the CGAL version coming with Ubuntu?
If not, then we could add something preventing from compiling the CGAL
library if a buggy compiler is used. But this will not solve the pb
for people using the version shipped with their distribution.
Sebastien.
Best,
Etienne
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/CGAL-segfaults-on-g-4-8-1-tp4660298.html
