cgal-discuss - Re: [cgal-discuss] Edge crossing counting for graph
  • To:
  • Subject: Re: [cgal-discuss] Edge crossing counting for graph
  • Date: Mon, 12 Jan 2015 21:33:32 -0800 (PST)
Andreas,
Thank you for your information. This is what I need - sweep line algorithm.
However, I got problems while running with large data. It works very well
with a few hundreds of segments but when working with a thousands or more
(my graph layout has around 20,500 segments), then the program is aborted
with error "Segmentation fault (core dumped)" or "double free or corruption
(fasttop): 0x0000000003a1ed30".
Jasmine,
andreas.fabri wrote
> Hello,
> Have a look at
> http://doc.cgal.org/latest/Sweep_line_2/index.html#Chapter_2D_Intersection_of_Curves
> andreas
> On 05/01/2015 01:14, jasmine2210 wrote:
>> Sebastien Loriot (GeometryFactory) wrote
>>> Could you explain what you mean by "counting edge crossing"?
>>> Sebastien.
>> Sebastien,
>> I meant the standard crossing number definition.
>> "In such a drawing, the intersection of two edges is called a /crossing/
>> (a
>> common endpoint of two edges does not count as a crossing)."
>> "Let G = (V,E) be a simple graph. The /crossing number/ of G , /cr(G)/,
>> is
>> the minimum number of crossings over all drawings of G."
>> Hope these definitions are clear enough.
>> Jasmine.
>> View this message in context:
>> http://cgal-discuss.949826.n4.nabble.com/Edge-crossing-counting-for-graph-tp4660258p4660270.html
>> Sent from the cgal-discuss mailing list archive at Nabble.com.
> Andreas Fabri, PhD
> Chief Officer, GeometryFactory
> Editor, The CGAL Project
> phone: +33.492.954.912 skype: andreas.fabri
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
http://cgal-discuss.949826.n4.nabble.com/Edge-crossing-counting-for-graph-tp4660258p4660303.html
