- To:
- Subject: [cgal-discuss] segmentation fault in refine_Delaunay_mesh_2
- Date: Wed, 14 Jan 2015 15:26:41 -0600
Does anyone have any insight about what might cause a segmentation fault when calling refine_Delaunay_mesh_2.
If I follow the steps in the example here: http://doc.cgal.org/latest/Mesh_2/Mesh_2_2mesh_global_8cpp-example.html
I get a mesh that refines perfectly well in some cases, but in others, I get a segmentation fault. If I run the program under gdb, I get a long message related to an iterator. The only strange thing I can see in the cases that fail is that two constraints intersect at a low angle. Will this cause a segmentation fault to occur?
- [cgal-discuss] segmentation fault in refine_Delaunay_mesh_2, Jack Stalnaker, 01/14/2015
- Re: [cgal-discuss] segmentation fault in refine_Delaunay_mesh_2, Marius Kintel, 01/14/2015
- Re: [cgal-discuss] segmentation fault in refine_Delaunay_mesh_2, Jack Stalnaker, 01/14/2015
- Re: [cgal-discuss] segmentation fault in refine_Delaunay_mesh_2, Jack Stalnaker, 01/15/2015
