cgal-discuss - Re: [cgal-discuss] AABB Tree: Seg fault
  • To:
  • Subject: Re: [cgal-discuss] AABB Tree: Seg fault
  • Date: Fri, 16 Jan 2015 16:54:19 -0600
I had the same problem a few weeks ago: turns out there is a bug in
GCC 4.8.2 that makes it compile the AABB module of CGAL incorrectly.
You will need to switch to a different version (I know 4.7.2 does
work) and recompile.
On Fri, Jan 16, 2015 at 4:49 PM, hardik kabaria
wrote:
> Hi everyone,
> I am having some trouble with AABB tree and finding closest point projection
> to a given query point.
> cgal @4.5 gis/cgal
> gcc version 4.8.2
> I have triangular mesh file ,
> and the corresponding .cpp file is pasted here
> #include <iostream>
> #include <CGAL/Simple_cartesian.h>
> #include <CGAL/Exact_predicates_inexact_constructions_kernel.h>
> #include <CGAL/AABB_tree.h>
> #include <CGAL/AABB_traits.h>
> #include <CGAL/Polyhedron_3.h>
> #include <CGAL/AABB_polyhedron_triangle_primitive.h>
> #include <CGAL/IO/Polyhedron_iostream.h>
> #include <iostream>
> #include <fstream>
> // typedef CGAL::Simple_cartesian<double> K;
> typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
> typedef K::FT FT;
> typedef K::Point_3 Point;
> typedef K::Segment_3 Segment;
> typedef CGAL::Polyhedron_3<K> Polyhedron;
> typedef CGAL::AABB_polyhedron_triangle_primitive<K,Polyhedron> Primitive;
> typedef CGAL::AABB_traits<K, Primitive> Traits;
> typedef CGAL::AABB_tree<Traits> Tree;
> typedef Tree::Object_and_primitive_id Object_and_primitive_id;
> typedef Tree::Point_and_primitive_id Point_and_primitive_id;
> int main()
> Point p(1.0, 0.0, 0.0);
> Point q(0.0, 1.0, 0.0);
> Point r(0.0, 0.0, 1.0);
> Point s(0.0, 0.0, 0.0);
> Polyhedron polyhedron;
> std::ifstream input("./poisson_rec.off");
> input>>polyhedron;
> // polyhedron.make_tetrahedron(p, q, r, s);
> // constructs AABB tree and computes internal KD-tree
> // data structure to accelerate distance queries
> Tree tree(polyhedron.facets_begin(),polyhedron.facets_end());
> tree.accelerate_distance_queries();
> // query point
> Point query(0.5, 0.5, 0.5);
> // computes squared distance from query
> FT sqd = tree.squared_distance(query);
> std::cout << "squared distance: " << sqd << std::endl;
> // computes closest point
> Point closest = tree.closest_point(query);
> std::cout << "closest point: " << closest << std::endl;
> // computes closest point and primitive id
> Point_and_primitive_id pp = tree.closest_point_and_primitive(query);
> Point cpt = tree.closest_point(Point(0.5,0.5,0.5));
> std::cout<<cpt<<std::endl;
> Point closest_point = pp.first;
> Polyhedron::Face_handle f = pp.second; // closest primitive id
> std::cout << "closest point: " << closest_point << std::endl;
> std::cout << "closest triangle: ( "
> << f->halfedge()->vertex()->point() << " , "
> << f->halfedge()->next()->vertex()->point() << " , "
> << f->halfedge()->next()->next()->vertex()->point()
> << " )" << std::endl;
> return EXIT_SUCCESS;
> It gives me segmentation fault. The .cpp is exactly that of
> AABB_polyhedron_facet_distance_example.cpp
> Can someone shade light on what am I doing wrong ?
> Thanks!
> Hardik Kabaria
> Ph.D. Candidate
> Department of Mechanical Engineering
> Stanford University
