cgal-discuss - [cgal-discuss] Delaunay_triangulation_3::flip(Cell_handle c, int i) invalidates the triangulation
  • To:
  • Subject: [cgal-discuss] Delaunay_triangulation_3::flip(Cell_handle c, int i) invalidates the triangulation
  • Date: Wed, 4 Feb 2015 22:07:50 -0800
Hello all,
For the following code:
void make_23_move(Delaunay* D3, std::vector<Cell_handle>* three_one,
                     std::vector<Cell_handle>* two_two) {
  // Pick a random (2,2)
  unsigned choice = generate_random_unsigned(three_one->size());
  std::cout << "We're picking (3,1) vector " << choice << std::endl;
  Cell_handle to_be_moved = (*three_one)[choice];
  for (size_t i = 0; i < 4; i++) {
    if (D3->flip(to_be_moved, i)) {
      // Delaunay::flip_flippable(to_be_moved,0)
      std::cout << "Facet " << i << " was flippable." << std::endl;
      break;
    } else {
      std::cout << "Facet " << i << " was not flippable." << std::endl;
Invoked in the test:
TEST_F(S3ErgodicMoves, MakeA23Move) {
  unsigned number_of_vertices_before = T.number_of_vertices();
  unsigned N3_31_before = three_one.size();
  unsigned N3_22_before = two_two.size();
  unsigned N3_13_before = one_three.size();
  std::cout << "Number of (2,2) simplices before = " << N3_22_before
            << std::endl;
  make_23_move(&T, &three_one, &two_two);
  // Now look at changes
  reclassify_3_simplices(&T, &three_one, &two_two, &one_three);
  unsigned N3_31_after = three_one.size();
  unsigned N3_22_after = two_two.size();
  unsigned N3_13_after = one_three.size();
  EXPECT_TRUE(T.is_valid())
  << "Triangulation is invalid.";
I've run these tests a couple dozen times, and every time there is a flippable edge the triangulation is invalidated, e.g.:
Repeating all tests (iteration 9) . . .
Note: Google Test filter = S3ErgodicMoves.MakeA23Move
[==========] Running 1 test from 1 test case.
[----------] Global test environment set-up.
[----------] 1 test from S3ErgodicMoves
[ RUN      ] S3ErgodicMoves.MakeA23Move
Generating universe ...
Pass #1
Fixing foliation....
Pass #2
Pass #3
Pass #4
Pass #5
Classifying simplices....
Valid foliation: true
Delaunay triangulation has 95251 cells.
There are 29713 (3,1) simplices and 35628 (2,2) simplices and 29910 (1,3) simplices.
Number of (2,2) simplices before = 35628
Random number is 27858
We're picking (3,1) vector 27858
Facet 0 was flippable.
../unittests/S3ErgodicMovesTest.cpp:82: Failure
Value of: T.is_valid()
  Actual: false
Expected: true
[  FAILED  ] S3ErgodicMoves.MakeA23Move (2229 ms)
[----------] 1 test from S3ErgodicMoves (2229 ms total)
[----------] Global test environment tear-down
[==========] 1 test from 1 test case ran. (2229 ms total)
[  PASSED  ] 0 tests.
[  FAILED  ] 1 test, listed below:
 1 FAILED TEST
Adam Getchell
"Invincibility is in oneself, vulnerability in the opponent." -- Sun Tzu
