cgal-discuss - Re: [cgal-discuss] CGAL 4.5.1 install fails on Solaris 10 Sparc 64 bit
  • To:
  • Subject: Re: [cgal-discuss] CGAL 4.5.1 install fails on Solaris 10 Sparc 64 bit
  • Date: Fri, 06 Feb 2015 11:24:05 +0100
SunPro is no supported compiler.
Best,
Andreas
On 06/02/2015 07:34, Michele31415 wrote:
cmake threw some warnings but doesn't seem to have failed. make though
didn't work at all. I haven't a clue why. Any help would be most
appreciated. Thanks!
# cmake .
-- The CXX compiler identification is SunPro 5.13.0
-- The C compiler identification is SunPro 5.13.0
-- Check for working CXX compiler: /usr/bin/CC
-- Check for working CXX compiler: /usr/bin/CC -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
== Setting paths ==
-- Build CGAL from release in directory CGAL-4.5.1
-- Packagenames: CGAL-4.5.1
== Setting paths (DONE) ==
== Generate version files ==
-- CGAL_MAJOR_VERSION=4
-- CGAL_MINOR_VERSION=5
-- CGAL_BUGFIX_VERSION=1
-- CGAL_SONAME_VERSION=10
-- CGAL_SOVERSION =10.0.4
-- CGAL_REFERENCE_CACHE_DIR=
-- Building shared libraries
-- Targetting Unix Makefiles
-- Using /usr/bin/CC compiler.
-- USING CMake version: 3.1.1
-- System: SunOS
-- Using SunPro compiler, using STLPort 4.
== Generate version files (DONE) ==
== Set up flags ==
-- Build type: Release
-- USING CXXFLAGS = ' -features=extensions -library=stlport4 -D_GNU_SOURCE
-xO3 -DNDEBUG'
-- USING LDFLAGS = ' -library=stlport4 '
== Set up flags (DONE) ==
== Detect external libraries ==
-- External libraries supported:
GMP;GMPXX;MPFR;ZLIB;OpenGL;LEDA;MPFI;RS;RS3;OpenNL;Eigen3;BLAS;LAPACK;QGLViewer;ESBTL;Coin3D;NTL;IPE
-- Preconfiguring library: GMP ...
-- Found GMP: /usr/local/lib/libgmp.so
-- GMP has been preconfigured:
-- UseGMP-file:
-- GMP include: /usr/local/include
-- GMP libraries: /usr/local/lib/libgmp.so
-- GMP definitions:
-- WARNING: GMP found but could not compile print_GMP_version.cpp:
-- GMP_INCLUDE_DIR=/usr/local/include
-- GMP_LIBRARIES=/usr/local/lib/libgmp.so
-- GMP_LIBRARIES_DIR=/usr/local/lib
-- Change Dir: /opt/CGAL-4.5.1/CMakeFiles/CMakeTmp
Run Build Command:"/opt/csw/bin/gmake" "cmTryCompileExec3707554004/fast"
/opt/csw/bin/gmake -f CMakeFiles/cmTryCompileExec3707554004.dir/build.make
gmake[1]: Entering directory '/opt/CGAL-4.5.1/CMakeFiles/CMakeTmp'
/usr/local/bin/cmake -E cmake_progress_report
/opt/CGAL-4.5.1/CMakeFiles/CMakeTmp/CMakeFiles 1
Building CXX object
CMakeFiles/cmTryCompileExec3707554004.dir/print_GMP_version.cpp.o
/usr/bin/CC -features=extensions -library=stlport4 -D_GNU_SOURCE
-I/usr/local/include -o
CMakeFiles/cmTryCompileExec3707554004.dir/print_GMP_version.cpp.o -c
/opt/CGAL-4.5.1/config/support/print_GMP_version.cpp
Linking CXX executable cmTryCompileExec3707554004
/usr/local/bin/cmake -E cmake_link_script
CMakeFiles/cmTryCompileExec3707554004.dir/link.txt --verbose=1
CMakeFiles/cmTryCompileExec3707554004.dir/print_GMP_version.cpp.o -o
cmTryCompileExec3707554004 -L/usr/local/lib /usr/local/lib/libgmp.so
-R/usr/local/lib
ld: fatal: file /usr/local/lib/libgmp.so: wrong ELF class: ELFCLASS64
ld: fatal: file processing errors. No output written to
CMakeFiles/cmTryCompileExec3707554004.dir/build.make:89: recipe for target
'cmTryCompileExec3707554004' failed
gmake[1]: Leaving directory '/opt/CGAL-4.5.1/CMakeFiles/CMakeTmp'
gmake[1]: *** [cmTryCompileExec3707554004] Error 2
Makefile:118: recipe for target 'cmTryCompileExec3707554004/fast' failed
gmake: *** [cmTryCompileExec3707554004/fast] Error 2
-- USING GMP_VERSION = 'unknown'
-- Preconfiguring library: MPFR ...
-- Found MPFR: /usr/local/lib/libmpfr.so
-- MPFR has been preconfigured:
-- UseMPFR-file:
-- MPFR include: /usr/local/include
-- MPFR libraries: /usr/local/lib/libmpfr.so
-- MPFR definitions:
-- WARNING: MPFR found but could not compile print_MPFR_version.cpp:
-- MPFR_INCLUDE_DIR=/usr/local/include
-- MPFR_LIBRARIES=/usr/local/lib/libmpfr.so
-- MPFR_LIBRARIES_DIR=/usr/local/lib
Run Build Command:"/opt/csw/bin/gmake" "cmTryCompileExec1764206712/fast"
/opt/csw/bin/gmake -f CMakeFiles/cmTryCompileExec1764206712.dir/build.make
Building CXX object
CMakeFiles/cmTryCompileExec1764206712.dir/print_MPFR_version.cpp.o
CMakeFiles/cmTryCompileExec1764206712.dir/print_MPFR_version.cpp.o -c
/opt/CGAL-4.5.1/config/support/print_MPFR_version.cpp
Linking CXX executable cmTryCompileExec1764206712
CMakeFiles/cmTryCompileExec1764206712.dir/link.txt --verbose=1
CMakeFiles/cmTryCompileExec1764206712.dir/print_MPFR_version.cpp.o -o
cmTryCompileExec1764206712 -L/usr/local/lib /usr/local/lib/libmpfr.so
/usr/local/lib/libgmp.so -R/usr/local/lib
ld: fatal: file /usr/local/lib/libmpfr.so: wrong ELF class: ELFCLASS64
CMakeFiles/cmTryCompileExec1764206712.dir/build.make:90: recipe for target
'cmTryCompileExec1764206712' failed
gmake[1]: *** [cmTryCompileExec1764206712] Error 2
Makefile:118: recipe for target 'cmTryCompileExec1764206712/fast' failed
gmake: *** [cmTryCompileExec1764206712/fast] Error 2
-- USING MPFR_VERSION = 'unknown'
-- Boost version: 1.54.0
-- Found the following Boost libraries:
-- thread
-- system
-- Boost include: /usr/local/include
-- Boost libraries:
/usr/local/lib/libboost_thread.so;/usr/local/lib/libboost_system.so
-- Boost definitions:
-- USING BOOST_VERSION = '1.54.0'
== Detect external libraries (DONE) ==
== Write compiler_config.h ==
-- Performing Test CGAL_CFG_BOOST_VARIANT_SWAP_BUG - Failed
-- Performing Test CGAL_CFG_DENORMALS_COMPILE_BUG - Success
-- Performing Test CGAL_CFG_FPU_ROUNDING_MODE_UNWINDING_VC_BUG - Success
-- Performing Test CGAL_CFG_IEEE_754_BUG - Success
-- Performing Test CGAL_CFG_ISTREAM_INT_BUG - Success
-- Performing Test CGAL_CFG_MATCHING_BUG_5 - Success
-- Performing Test CGAL_CFG_MATCHING_BUG_6 - Failed
-- Performing Test CGAL_CFG_MATCHING_BUG_7 - Success
-- Performing Test CGAL_CFG_MATCHING_BUG_8 - Success
-- Performing Test CGAL_CFG_NESTED_CLASS_FRIEND_DECLARATION_BUG - Failed
-- Performing Test CGAL_CFG_NO_LIMITS - Failed
-- Performing Test CGAL_CFG_NO_NEXTAFTER - Success
-- Performing Test CGAL_CFG_NO_STL - Success
-- Performing Test CGAL_CFG_NO_WARNING_CPP_DIRECTIVE_BUG - Success
-- Performing Test CGAL_CFG_NUMERIC_LIMITS_BUG - Success
-- Performing Test CGAL_CFG_OUTOFLINE_MEMBER_DEFINITION_BUG - Success
-- Performing Test CGAL_CFG_TEMPLATE_IN_DEFAULT_PARAMETER_BUG - Success
-- Performing Test CGAL_CFG_TYPENAME_BEFORE_DEFAULT_ARGUMENT_BUG - Success
-- Performing Test CGAL_CFG_USING_BASE_MEMBER_BUG_2 - Success
== Write compiler_config.h (DONE) ==
== Generating build files ==
Configuring libCGAL
-- Requested component: MPFR
-- Requested component: GMP
libCGAL is configured
-- Sources for CGAL component library 'CGAL_ImageIO' detected
Configuring libCGAL_ImageIO
-- Looking for XOpenDisplay in /usr/lib/libX11.so;/usr/lib/libXext.so
-- Looking for XOpenDisplay in /usr/lib/libX11.so;/usr/lib/libXext.so -
found
-- Looking for gethostbyname
-- Looking for gethostbyname - not found
-- Looking for gethostbyname in nsl
-- Looking for gethostbyname in nsl - found
-- Looking for connect
-- Looking for connect - not found
-- Looking for connect in socket
-- Looking for connect in socket - found
-- Looking for remove
-- Looking for remove - found
-- Looking for shmat
-- Looking for shmat - found
-- Looking for IceConnectionNumber in ICE
-- Looking for IceConnectionNumber in ICE - found
-- Found X11: /usr/lib/libX11.so
-- Found OpenGL: /usr/lib/libGL.so
-- Found ZLIB: /usr/local/lib/libz.so (found version "1.2.8")
-- OpenGL include: /usr/include
-- OpenGL libraries:
/usr/lib/libGLU.so;/usr/lib/libGL.so;/usr/lib/libSM.so;/usr/lib/libICE.so;/usr/lib/libX11.so;/usr/lib/libXext.so;-lsocket;-lnsl
-- USING ZLIB_VERSION = '1.2.8'
libCGAL_ImageIO is configured
-- Sources for CGAL component library 'CGAL_Core' detected
Configuring libCGAL_Core
libCGAL_Core is configured
-- Sources for CGAL component library 'CGAL_Qt3' detected
Configuring libCGAL_Qt3
-- libCGAL_Qt3 needs Qt3, cannot be configured.
-- Sources for CGAL component library 'CGAL_Qt4' detected
Configuring libCGAL_Qt4
-- USING OPENGL_VERSION = '2.0'
-- USING QT4_VERSION = '4.5.3'
-- OpenGL definitions:
-- Qt4 include: /opt/aard/qt4/include
-- Qt4 libraries:
/opt/aard/qt4/lib/libQtOpenGL.so;/opt/aard/qt4/lib/libQtGui.so;/opt/aard/qt4/lib/libQtCore.so
-- Qt4 definitions:
-- moc executable: /opt/aard/qt4/bin/moc
-- uic executable: /opt/aard/qt4/bin/uic
libCGAL_Qt4 is configured
-- Sources for CGAL component libraries
'CGAL_Core;CGAL_ImageIO;CGAL_Qt3;CGAL_Qt4' detected
== Generating build files (DONE) ==
-- Configuring done
-- Generating done
-- Build files have been written to: /opt/CGAL-4.5.1
# ls
AUTHORS CMakeLists.txt LICENSE.GPL auxiliary
doc_html src
CGALConfig.cmake INSTALL LICENSE.LGPL cmake
examples
CHANGES LICENSE Makefile cmake_install.cmake
include
CMakeCache.txt LICENSE.BSL README config lib
CMakeFiles LICENSE.FREE_USE VERSION demo
scripts
# make
Scanning dependencies of target CGAL
[ 5%] Building CXX object src/CGAL/CMakeFiles/CGAL.dir/all_files.cpp.o
"/opt/CGAL-4.5.1/src/CGAL/Random.cpp", line 50: Warning: seed hides
CGAL::Random::seed.1 Warning(s) detected.
Linking CXX shared library ../../lib/libCGAL.so
../../lib/libCGAL.so.10.0.4
src/CGAL/CMakeFiles/CGAL.dir/build.make:89: recipe for target
'lib/libCGAL.so.10.0.4' failed
make[2]: *** [lib/libCGAL.so.10.0.4] Error 2
CMakeFiles/Makefile2:195: recipe for target
'src/CGAL/CMakeFiles/CGAL.dir/all' failed
make[1]: *** [src/CGAL/CMakeFiles/CGAL.dir/all] Error 2
Makefile:117: recipe for target 'all' failed
make: *** [all] Error 2
# gmake
gmake[2]: *** [lib/libCGAL.so.10.0.4] Error 2
gmake[1]: *** [src/CGAL/CMakeFiles/CGAL.dir/all] Error 2
gmake: *** [all] Error 2
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/CGAL-4-5-1-install-fails-on-Solaris-10-Sparc-64-bit-tp4660404.html
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
