- To:
- Subject: Re: [cgal-discuss] Understanding Nef Polyhedron documentation
- Date: Fri, 13 Feb 2015 07:51:13 +0100
On 01/27/2015 12:30 PM, Pranav wrote:
Hi,The definition is given in (), it is the set of positive real numbers.
I am studying Nef polyhedron documentation. The 1st figure in /Definition/
section, shows local pyramids for all faces of the polyhedron /P/.
I would like to know the following:
1. What does /R+/ mean in definition of local pyramid /Q/(in the
documentation)?
It's any simplex (from dimension 0 to d-1).
2. Since /Pyr/ is defined only for points in d-dimensional space, does
Pyr(f) where /f/ is a 2-face is compact representation of referring to all
points in face /f/ at once?
3. How local pyramid of face /f1/ is Null? I find it a bit confusing becauseIt is null if it is a volume not in the nef.
as per definition of local pyramid /Q = x + (R+)*(Intersection(P, U(x)) -
x)/ and here /x/ is a point in the d-dimensional space. It means at least
/x/ is always a part of /Q/, thereby making it a non-empty set.
Sebastien.
Thanks in advance,
Pranav
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Understanding-Nef-Polyhedron-documentation-tp4660361.html
- Re: [cgal-discuss] Understanding Nef Polyhedron documentation, Sebastien Loriot (GeometryFactory), 02/13/2015
