Re: [cgal-discuss] Uncatchable exception converting from Nef polyhedron to Polyhedron_3
- To:
- Subject: Re: [cgal-discuss] Uncatchable exception converting from Nef polyhedron to Polyhedron_3
- Date: Wed, 18 Feb 2015 08:34:43 +0100
On 02/17/2015 10:40 PM, kintel wrote:
Bump.
The issue is that CGAL throws exceptions from destructors. These exceptions
are not catchable and causes programs to terminate. Read e.g.
http://www.kolpackov.net/projects/c++/eh/dtor-1.xhtml
See e.g. ~Polyhedron_incremental_builder_3()
We work around this by forking parts of CGAL into our own sources and patch
it to submission, which is far from ideal.
-Marius
Your input is self-intersecting which is why you have this error.
If you import the model using OFF_to_nef_3 and then try to export
to polyhedron, you'll get the following assertion:
terminate called after throwing an instance of 'CGAL::Precondition_exception'
what(): CGAL ERROR: precondition violation!
Expr: is_simple()
File: /home/sloriot/CGAL/git/cgal/Nef_3/include/CGAL/Nef_polyhedron_3.h
Line: 1041
Aborted
because of the self-intersection that was fixed during the import to Nef_3.
Is it an option to test for self-intersections before trying to do this?
(using CGAL::self_intersect(P) from include/CGAL/Self_intersection_polyhedron_3.h for example)
Sebastien.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Uncatchable-exception-converting-from-Nef-polyhedron-to-Polyhedron-3-tp4658603p4660455.html
- Re: [cgal-discuss] Uncatchable exception converting from Nef polyhedron to Polyhedron_3, kintel, 02/17/2015
- Re: [cgal-discuss] Uncatchable exception converting from Nef polyhedron to Polyhedron_3, Sebastien Loriot (GeometryFactory), 02/18/2015
- Re: [cgal-discuss] Uncatchable exception converting from Nef polyhedron to Polyhedron_3, Giles Bathgate, 02/18/2015
- Re: [cgal-discuss] Uncatchable exception converting from Nef polyhedron to Polyhedron_3, Sebastien Loriot (GeometryFactory), 02/19/2015
- Re: [cgal-discuss] Uncatchable exception converting from Nef polyhedron to Polyhedron_3, Marius Kintel, 02/20/2015
- Re: [cgal-discuss] Uncatchable exception converting from Nef polyhedron to Polyhedron_3, Sebastien Loriot (GeometryFactory), 02/20/2015
- Re: [cgal-discuss] Uncatchable exception converting from Nef polyhedron to Polyhedron_3, Giles Bathgate, 02/20/2015
- Re: [cgal-discuss] Uncatchable exception converting from Nef polyhedron to Polyhedron_3, Sebastien Loriot (GeometryFactory), 02/23/2015
- Re: [cgal-discuss] Uncatchable exception converting from Nef polyhedron to Polyhedron_3, Giles Bathgate, 02/23/2015
