- To:
- Subject: Re: [cgal-discuss] Equilateral triangular mesh generation
- Date: Thu, 19 Feb 2015 09:33:33 +0100
Le 18/02/15 17:48, Houssem GHIAT a écrit :
a mesh composed of equilateral triangles
With equilateral triangles, you can mesh only very special objects.
(e.g. if your object is a polyhedron, you need angles of all faces to be 60 degrees
+ hypotheses on lengths of edges)
- [cgal-discuss] Equilateral triangular mesh generation, Houssem GHIAT, 02/18/2015
- Re: [cgal-discuss] Equilateral triangular mesh generation, Sebastien Loriot (GeometryFactory), 02/19/2015
- Re: [cgal-discuss] Equilateral triangular mesh generation, Olivier Devillers, 02/19/2015
- Re: [cgal-discuss] Equilateral triangular mesh generation, Houssem GHIAT, 02/19/2015
