cgal-discuss - Re: [cgal-discuss] Kernel
  • To:
  • Subject: Re: [cgal-discuss] Kernel
  • Date: Thu, 19 Feb 2015 14:15:12 +0100
On 02/19/2015 02:08 PM, thierry Fernandez wrote:
I watched these pages, but why integers?
The example is using homogenous coordinates which is why an integer type is sufficient.
If you use CGAL::Extended_cartesian then you can use a rational type.
http://doc.cgal.org/latest/Nef_2/classCGAL_1_1Extended__cartesian.html
Side remark: if you're looking for the close intersection of a set of
halfspaces then a function doing exactly this will be included in the
next release of CGAL (the beta is expected before the end of the month).
Sebastien.
2015-02-19 11:29 GMT+01:00 Sebastien Loriot (GeometryFactory)
<mailto:>>:
On 02/19/2015 10:01 AM, thierry Fernandez wrote:
ok but i want to construct Nef_Polyedron_3 with plane_3, and this 2
kernels doesn't work.
Sorry for not having guessed, my daughter broke my crystal ball
recently.
You're in the unlucky case where you indeed need to use an extended
kernel like in this example:
http://doc.cgal.org/latest/__Nef_3/index.html#Nef___3UsinganExtendedKernel
<http://doc.cgal.org/latest/Nef_3/index.html#Nef_3UsinganExtendedKernel>
See also:
http://doc.cgal.org/latest/__Nef_3/index.html#sectionNef___3InfiBox
<http://doc.cgal.org/latest/Nef_3/index.html#sectionNef_3InfiBox>
Sebastien.
2015-02-19 9:21 GMT+01:00 Sebastien Loriot (GeometryFactory)
<mailto:>
<mailto:
<mailto:>>>__:
On 02/18/2015 04:14 PM, tfern90 wrote:
why so many kernel in cgal ????
See http://www.cgal.org/FAQ.html#____kernels
<http://www.cgal.org/FAQ.html#__kernels>
<http://www.cgal.org/FAQ.html#kernels>>
In practice,
Exact_predicates_inexact_____constructions_kernel and
Exact_predicates_exact_____constructions_kernel will fit
most of the
needs.
Sebastien.
View this message in context:
http://cgal-discuss.949826.n4.____nabble.com/Kernel-tp4660465.____html
<http://nabble.com/Kernel-tp4660465.__html>
<http://cgal-discuss.949826.__n4.nabble.com/Kernel-__tp4660465.html
<http://cgal-discuss.949826.n4.nabble.com/Kernel-tp4660465.html>>
Sent from the cgal-discuss mailing list archive at
Nabble.com.
https://sympa.inria.fr/sympa/____info/cgal-discuss
<https://sympa.inria.fr/sympa/__info/cgal-discuss>
<https://sympa.inria.fr/sympa/info/cgal-discuss>>
