- To:
- Subject: Re: [cgal-discuss] Is CGAL::Orthogonal_k_neighbor_search thread-safe?
- Date: Mon, 23 Feb 2015 15:32:29 +0100
On 02/23/2015 03:16 PM, Antonio Carlos Pereira de Azambuja wrote:
Hello, Sebastien!
I just can't get my test work. I'm trying to test if serial code and
parallel code performing CGAL::Orthogonal_k_neighbor_search work on 4D.
Both should return the same results for the same queries. If I run the
test for some time executing the same test in an outside loop (it means,
allocating and deallocation everytime) some problems occurs with
deallocation at some point and a segfault arises.
Considering the statements below are correct:
i) Cartesian_d<double>::Point_d inherits from PointCd2
ii) PointCd2 inherits from Handle_for<tuple..>
iii) Handle_for uses reference counters.
I am wondering if the reference counting strategy (in Handle_for) could
be the cause of this errors?
Indeed, the class Handle_for is not yet thread-safe.
We'll provide soon an official fix for that.
In the meantime you can try the one provided in this mailing list:
https://sympa.inria.fr/sympa/arc/cgal-discuss/2015-01/msg00073.html
Sebastien.
Thanks
-- Antonio Azambuja
2015-02-12 11:54 GMT-02:00 Sebastien Loriot (GeometryFactory)
<mailto:>>:
On 02/12/2015 02:53 PM, Antonio Carlos Pereira de Azambuja wrote:
Hi,
I am using CGAL to solve nearest neighbor search in 4 dimensional.
I would like to know if I can build a single kdtree object and
perform
parallel searches in each thread of an OMP loop. Each thread has
its own
search object. The problem could be illustrated by the draft
code below:
int main(void)
// create a kdTree from a point cloud
CGAL::Orthogonal_k_neighbor___search<Traits>::Tree *kdTree;
kdTree = new
CGAL::Orthogonal_k_neighbor___search<Traits>::Tree(
points.begin(), points.end() )
// perform several searches in an OMP loop
#pragma omp parallel .....
for (counter =0; ....)
CGAL::Cartesian_d<FT>::Point_d query(......); // define a
query point
CGAL::Orthogonal_k_neighbor___search<Traits> search(
*kdTree,
query, 1);
} //end for
}//end main
Thanks in advance for any help.
-- Antonio Azambuja
Yes it is.
Sebastien.
https://sympa.inria.fr/sympa/__info/cgal-discuss
<https://sympa.inria.fr/sympa/info/cgal-discuss>
- [cgal-discuss] Is CGAL::Orthogonal_k_neighbor_search thread-safe?, Antonio Carlos Pereira de Azambuja, 02/12/2015
- Re: [cgal-discuss] Is CGAL::Orthogonal_k_neighbor_search thread-safe?, Sebastien Loriot (GeometryFactory), 02/12/2015
- Re: [cgal-discuss] Is CGAL::Orthogonal_k_neighbor_search thread-safe?, Antonio Carlos Pereira de Azambuja, 02/23/2015
- Re: [cgal-discuss] Is CGAL::Orthogonal_k_neighbor_search thread-safe?, Sebastien Loriot (GeometryFactory), 02/23/2015
