- To:
- Subject: Re: [cgal-discuss] Enlarging/Thickening a Polyhedron_3 or Nef_polyhedron_3
- Date: Tue, 3 Mar 2015 08:23:26 -0800
Hi,
I have a non-CGAL suggestion. You can use Blender to create an offset mesh (e.g. [1]). The approach would be:On Tue, Mar 3, 2015 at 7:58 AM, Alexander Teibrich <> wrote:
Hi,I'm looking for a way to enlarge/thicken a non-convex Polyhedron_3 or Nef_polyhedron_3 A by a certain distance x to get B. Basically something like the outset function of inkscape [1]. Scaling alone is not an option, since I have to ensure that B is strictly contained in A.My current approach is to iterate through all vertices and shift each vertices by x along the vertex normal, that is the average of the normals of all adjoining faces. This works with simple geometries, but quickly leads to self-intersecting faces and invalid Polyhedron_3 / Nef_polyhedron_3 with more complex geometries. Intersecting or overlapping geometries are not strictly a problem, but the geometry has to valid and manifold to be used for future CSG operations.Shifting A into all possible directions (in 90° or 45° steps) and doing a union operation over all translations would work, but is horribly slow.Is there a better way to do this?Thanks!Alex--Alexander Teibrich
- [cgal-discuss] Enlarging/Thickening a Polyhedron_3 or Nef_polyhedron_3, Alexander Teibrich, 03/03/2015
- Re: [cgal-discuss] Enlarging/Thickening a Polyhedron_3 or Nef_polyhedron_3, Alex Tsui, 03/03/2015
- Re: [cgal-discuss] Enlarging/Thickening a Polyhedron_3 or Nef_polyhedron_3, Alexander Teibrich, 03/03/2015
