cgal-discuss - Re: [cgal-discuss] CGAL Surface mesh generation
  • To:
  • Subject: Re: [cgal-discuss] CGAL Surface mesh generation
  • Date: Tue, 3 Mar 2015 13:41:29 -0800 (PST)
Thank you for your reply.. I am getting compilation errors. I understand
that they are coming while I am reading the image. specifically read
function in CGAL.
I am trying to read a 3d labelled voxels and trying to mesh it as complete
3d and 3d surface. I am successful in generating full 3d mesh but not 3d
surface mesh.
For complete 3d image I followed same steps as liver example in CGAL.
In CGAL 3d meshing example, reading an image is performed by the following
steps
// Loads image
CGAL::Image_3 image;
image.read("data/liver.inr.gz");
// Domain
Mesh_domain domain(image);
But in 3d surface meshing example
// the 'function' is a 3D gray level image
Gray_level_image image("data/skull_2.9.inr", 2.9f);
Could you explain what is the difference between 3d surface mesh and 3d mesh
in-terms of reading the image into CGAL.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/CGAL-Surface-mesh-generation-tp4660545p4660552.html
