- To:
- Subject: Re: [cgal-discuss] Bug report: Incrementing an invalid iterator
- Date: Wed, 11 Mar 2015 11:00:58 +0100
What are you reporting exactly? That you might have a bug in your code
and you need some help to figure it out or you know there is a bug in
CGAL?
Do you have an example showing it?
Sebastien
On 03/11/2015 02:48 AM, Adam Getchell wrote:
Summary:
Building in debug mode produces errors (see below).
Building in release mode doesn't (see below).
Details:
Operating system: 10.10.2
Compiler: AppleClang 6.0.0.6000057
Hardware: MacBook Pro (Retina, Mid 2012)
Version:
┌─[*adam*][Hapkido][*±*][master *✗*][~/CDT-plusplus/build]
└─▪ brew info cgal
cgal: stable 4.5.2 (bottled)
http://www.cgal.org/
/usr/local/Cellar/cgal/4.5.2 (2731 files, 33M) *
Built from source with: --c++11, --imaging, --with-eigen3, --with-lapack
https://github.com/Homebrew/homebrew/blob/master/Library/Formula/cgal.rb
*==>**Dependencies*
Build: cmake *✔*
Required: boost *✔*, gmp *✔*, mpfr *✔*
*==>**Options*
--c++11
Build using C++11 mode
--imaging
Build ImageIO and QT compoments of CGAL
--with-eigen3
Build with Eigen3 support
--with-lapack
Build with LAPACK support
└─▪ brew info tbb
tbb: stable 4.3-20141023 (bottled)
http://www.threadingbuildingblocks.org/
/usr/local/Cellar/tbb/4.3-20141023 (104 files, 1.9M) *
https://github.com/Homebrew/homebrew/blob/master/Library/Formula/tbb.rb
*==>**Options*
--c++11
gmock-1.7.0
Kernel:
Linking unittests fails:
*Scanning dependencies of target unittests*
[ 27%] Building CXX object CMakeFiles/unittests.dir/unittests/main.cpp.o
[ 36%] Building CXX object
CMakeFiles/unittests.dir/unittests/PointTest.cpp.o
[ 45%] Building CXX object
CMakeFiles/unittests.dir/unittests/S3BulkActionTest.cpp.o
[ 54%] Building CXX object
CMakeFiles/unittests.dir/unittests/S3ErgodicMovesTest.cpp.o
[ 63%] Building CXX object
CMakeFiles/unittests.dir/unittests/S3TetrahedronTest.cpp.o
[ 72%] Building CXX object
CMakeFiles/unittests.dir/unittests/SdTriangulationTest.cpp.o
[ 81%] Building CXX object
CMakeFiles/unittests.dir/unittests/SphereTest.cpp.o
[ 90%] Building CXX object
CMakeFiles/unittests.dir/unittests/Triangulated2SphereTest.cpp.o
[100%] Building CXX object
CMakeFiles/unittests.dir/unittests/VertexTest.cpp.o
*Linking CXX executable unittests*
Undefined symbols for architecture x86_64:
"tbb::task_group_context::init()", referenced from:
Full debug dump is here.
https://gist.github.com/acgetchell/3466c16aa47fb80c6199
However, the main program builds:
└─▪ make
*Scanning dependencies of target cdt*
[ 9%] Building CXX object CMakeFiles/cdt.dir/src/cdt.cpp.o
[ 18%] Building CXX object CMakeFiles/cdt.dir/src/docopt/docopt.cpp.o
*Linking CXX executable cdt*
[ 18%] Built target cdt
Running the main program produces the following:
└─▪ ./cdt --s -n6400 -t256 -a1.1 -k2.2 -l3.3 -p1000
Topology is spherical
Number of dimensions = 3
Number of simplices = 6400
Number of timeslices = 256
Alpha = 1.1
K = 2.2
Lambda = 3.3
Number of passes = 1000
User = adam
Hostname = Hapkido.local
Generating universe ...
Pass #1
Fixing foliation....
CGAL error: assertion violation!
Expression : DSC::type(m_ptr.p) == DSC::USED
File : /usr/local/Cellar/cgal/4.5.2/include/CGAL/Compact_container.h
Line : 1076
Explanation: Incrementing an invalid iterator.
Refer to the bug-reporting instructions at
http://www.cgal.org/bug_report.html
libc++abi.dylib: terminating with uncaught exception of type
CGAL::Assertion_exception: CGAL ERROR: assertion violation!
Expr: DSC::type(m_ptr.p) == DSC::USED
File: /usr/local/Cellar/cgal/4.5.2/include/CGAL/Compact_container.h
Line: 1076
Abort trap: 6
If I build in release mode everything works:
┌─[*adam*][Hapkido][*±*][master *✗*][~/CDT-plusplus]
└─▪ ./build.sh
-- The C compiler identification is AppleClang 6.0.0.6000057
-- The CXX compiler identification is AppleClang 6.0.0.6000057
-- Check for working C compiler using: Ninja
-- Check for working C compiler using: Ninja -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler using: Ninja
-- Check for working CXX compiler using: Ninja -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Build type: Release
-- USING CXXFLAGS = ' -O3 -DNDEBUG'
-- USING EXEFLAGS = '
-Wl,-dylib_file,/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib:/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
-- Targetting Ninja
-- Using /usr/bin/c++ compiler.
-- DARWIN_VERSION=14
-- Mac Leopard detected
-- Requested component: Core
-- Requested component: MPFR
-- Requested component: GMP
-- Found Eigen3: /usr/local/include/eigen3 (found suitable version
"3.2.4", minimum required is "3.1.0")
-- Found Intel TBB
-- Configuring done
-- Generating done
-- Build files have been written to: /Users/adam/CDT-plusplus/build
[13/13] Linking CXX executable unittests
└─▪ ./build/cdt --s -n6400 -t256 -a1.1 -k2.2 -l3.3 -p1000
Alpha = 1.1
K = 2.2
Lambda = 3.3
User = adam
Pass #1
Pass #2
Pass #3
Classifying simplices....
Valid foliation: true
Delaunay triangulation has 1089 cells.
There are 365 (3,1) simplices and 341 (2,2) simplices and 383 (1,3)
simplices.
Universe has been initialized ...
Now performing 1000 passes of ergodic moves.
Final Delaunay triangulation has 210 vertices and 1334 edges and 2214
faces and 1089 cells
Running time is 2.794 seconds.
Writing to file :46:21PDT.dat
Adam Getchell
about.me/adamgetchell <http://about.me/adamgetchell>
"Invincibility is in oneself, vulnerability in the opponent." -- Sun Tzu
- [cgal-discuss] Bug report: Incrementing an invalid iterator, Adam Getchell, 03/11/2015
- Re: [cgal-discuss] Bug report: Incrementing an invalid iterator, Sebastien Loriot (GeometryFactory), 03/11/2015
