- To:
- Subject: [cgal-discuss] ET of Quadratic Program Solution
- Date: Thu, 12 Mar 2015 18:29:44 -0700 (PDT)
Hi everyone,
I'm trying to use the quadratic program class in CGAL. I tried the first
example in the manual and see the same result.
However, when I change the constraint -x + 2y <= 4 to -x + 1.8y <= 4 by
calling qp.set_a(1, 1, 1.8), it gives result as follow (for changing the
constraint, I've changed the NT of QP class from int to double):
status: OPTIMAL
objective value: 0/1
variable values:
0: 0/1
1: 4/1
, which is obviously not the optimal solution. But if I change the ET of QP
Solution from Gmpz to MP_Float, it gives:
status: OPTIMAL
objective value: 1.61559e-029/2.85568e-030
variable values:
0: 25.6/14.48
1: 46.4/14.48
, which is more reasonable.
I think both Gmpz and MP_Float give arbitrary solution, so where did I go
wrong?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/ET-of-Quadratic-Program-Solution-tp4660574.html
- [cgal-discuss] ET of Quadratic Program Solution, Narusaki, 03/13/2015
- Re: [cgal-discuss] ET of Quadratic Program Solution, Ronan Torrecillos, 03/13/2015
- Re: [cgal-discuss] ET of Quadratic Program Solution, Narusaki, 03/13/2015
