- To:
- Subject: Re: [cgal-discuss] Why do the OFF_to_nef_3 take so much time?
- Date: Fri, 13 Mar 2015 06:32:52 -0700 (PDT)
Hi Sebastion,
Could you tell me how you have defined "Kernel" in your sample code (shown
at bottom)?
When I define it as CGAL::Homogeneous<CGAL::Gmpz>, I get thousands of
run-time warnings telling me that the data being read-in is "double" when it
should be "integer":
Line : 102
Explanation: Gmpz constructed from non-integer double value
Refer to the bug-reporting instructions at
http://www.cgal.org/bug_report.html
CGAL warning: check violation!
Expression : is_integer(d)
And then eventually the program crashes.
When I use any other type, compilation fails.
(CGAL::Gmpzf, CGAL::Gmpfr...)
My test data is "s.off" in this location:
https://docs.google.com/file/d/0B4PDrM6_sr2UdzFJYTZYOWdTb2VJTkp5WmVuXzAxdw/edit
Thanks,
Kevin Hartmann
------- Sebastion's sample code ------------------
#include <CGAL/IO/Polyhedron_iostream.h>
std::ofstream file("myoff.off");
Polyhedron_3<Kernel> P;
file >> P;
Nef_polyhedron_3<Kernel> nef(P);
(ofstream should be ifstream)
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Why-do-the-OFF-to-nef-3-take-so-much-time-tp4440642p4660580.html
- Re: [cgal-discuss] Why do the OFF_to_nef_3 take so much time?, KHartmann, 03/13/2015
- Re: [cgal-discuss] Why do the OFF_to_nef_3 take so much time?, Sebastien Loriot (GeometryFactory), 03/14/2015
- Re: [cgal-discuss] Why do the OFF_to_nef_3 take so much time?, KHartmann, 03/16/2015
- Re: [cgal-discuss] Why do the OFF_to_nef_3 take so much time?, Sebastien Loriot (GeometryFactory), 03/17/2015
- Re: [cgal-discuss] Why do the OFF_to_nef_3 take so much time?, Marius Kintel, 03/17/2015
