cgal-discuss - Re: [cgal-discuss] Algorithm to extract approximating polygon
  • To:
  • Subject: Re: [cgal-discuss] Algorithm to extract approximating polygon
  • Date: Sat, 14 Mar 2015 10:24:31 -0700 (PDT)
Hi,
Thank you for such detailed explanation.
But i`m not fully sure how it can help with initial question/problem.
There is no problem with using alpha_shape algorithm that identifies
boundary points. The question is: which algorithm or set of algorithms might
be used to extract polygons(get actual physical meaning) from remaining
boundary points. e.g. square or triangle etc...
Appreciate if someone can advise.
Best Regards,
Igor
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Algorithm-to-extract-approximating-polygon-tp4660582p4660586.html
