- To:
- Subject: [cgal-discuss] Closest Point with NOT triangular mesh
- Date: Wed, 18 Mar 2015 10:12:43 -0700 (PDT)
Hi!
I am fairly new to CGAL and I use it to find the minimum distance between a
point and a given object.
I searched among previous posts, but I didn't find anything similar to my
problem, so I post this new message.
At first, I explain my situation.
I have an object, represented with an OFF model; in particular, let's
consider a box.
So, using OFF rules, this box is represented with 8 vertices and 6
rectangular faces.
I use tree.closest_point() to find the closest point of the box respect of
a given external point and tree.squared_distance() to find the required
distance.
My question is:
is able CGAL to work with not triangular mesh/faces?
In my case, I am able to find correct distance with tree:squared_distance()
only if I represent the box with triangulare faces.
I hope somebody will be able to help me :)
P.s:
If someone is interested and thinks that this message is not enough I can
explain my problem with more details :)
Best regards,
GV
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Closest-Point-with-NOT-triangular-mesh-tp4660593.html
- [cgal-discuss] Closest Point with NOT triangular mesh, GV, 03/18/2015
- Re: [cgal-discuss] Closest Point with NOT triangular mesh, Zohar, 03/23/2015
- Re: [cgal-discuss] Closest Point with NOT triangular mesh, GV, 03/23/2015
