- To: "" <>
- Subject: Re: [cgal-discuss] Mesh_3: Mesh polyhedral domain with features
- Date: Fri, 8 May 2015 16:03:42 -0700
Hi Laurent,
I am having tough time getting the right parameters / meshing criteria. Can you tell me how to choose the
parameter for the following .off file here .
Thanks,
On Fri, May 8, 2015 at 4:02 PM, hardik kabaria <> wrote:
Hi Laurent,I am having tough time getting the right parameters / meshing criteria. Can you tell me how to choose theparameter for the following .off file.Thanks,Hardik--On Fri, May 8, 2015 at 4:15 AM, Laurent Rineau (CGAL/GeometryFactory) <> wrote:Le Thursday 07 May 2015 16:38:28 hardik kabaria a écrit :
> Hello,
> I am trying to use the example file:
> mesh_polyhedral_domain_with_features.cpp for a geometry I need to mesh.
> Is there a way to automatically genearte criteria for the given geometry. I
> always end up doing hit and trial with the criteria.
You can compute the dimensions (max length for example) of the object, and
scale the sizes and distance criteria.
Laurent Rineau, PhD
Hardik Kabaria
Ph.D. Candidate
Department of Mechanical Engineering
Stanford University
Hardik Kabaria
Ph.D. Candidate
Stanford University
Ph.D. Candidate
Stanford University
- [cgal-discuss] Mesh_3: Mesh polyhedral domain with features, hardik kabaria, 05/08/2015
- Re: [cgal-discuss] Mesh_3: Mesh polyhedral domain with features, Laurent Rineau (CGAL/GeometryFactory), 05/08/2015
- Message not available
- Re: [cgal-discuss] Mesh_3: Mesh polyhedral domain with features, hardik kabaria, 05/09/2015
- Re: [cgal-discuss] Mesh_3: Mesh polyhedral domain with features, Andreas Fabri, 05/10/2015
