cgal-discuss - [cgal-discuss] Reply: 回复: Problem on Poisson Surface reconstruction
  • To:
  • Subject: [cgal-discuss] Reply: 回复: Problem on Poisson Surface reconstruction
  • Date: Mon, 11 May 2015 08:49:01 +0800 (GMT+08:00)
Thank you!
I use the No_mainforld_tag() and it works.
-----原始邮件-----
发件人: xyzmail <>
发送时间: 2015年5月9日 星期六
收件人: cgal-discuss <>
抄送:
主题: [cgal-discuss] 回复: Problem on Poisson Surface reconstruction
i think there is the same point in your dataset.
发自我的酷派手机!
11硕博 隋伟 编写:
发件人:11硕博 隋伟
收件人:;
抄送:
主题:[cgal-discuss] Problem on Poisson Surface reconstruction
Hello,
I'm using CGAL's Surface Mesher generate surface on 3D points. It works well
on the dataset in examples. However when I test it on my own data errors occurs.
terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
File: ../myLibs/CGAL-4.2/include/CGAL/Surface_mesher/Surface_mesher.h
Line: 249
Explanation: (-4.89829 2.14556 3.70213) is already inserted on surface.
The program has unexpectedly finished.
Can any one can help me?
Thank you very much!
> -----原始邮件-----
> 发件人: "Olivier Devillers" <>
> 发送时间: 2015年5月7日 星期四
> 收件人:
> 抄送:
> 主题: Re: [cgal-discuss] Invalid TDS after inserting vertices and creating cells & neighbors
> Le 07/05/15 10:17, Adam Getchell a écrit :
> > 3. Which modifiers affect the validity of the TDS?
> >> look for create_vertex in
> >> http://doc.cgal.org/latest/TDS_3/classTriangulationDataStructure__3.html
> >> Other modifiers
> >> The following modifiers can affect the validity of the triangulation data structure.
> > What modifiers?
> The modifiers in the section "Other modifiers" of that page
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
