[cgal-discuss] How to do Edge collapse on Polyhedron_3 using user defined cost function
- To:
- Subject: [cgal-discuss] How to do Edge collapse on Polyhedron_3 using user defined cost function
- Date: Wed, 13 May 2015 02:14:54 +0300
I'm coding mesh simplification using edge collapse method with two different cost functions
1. The edge length and the local curvature cost formula by Stan Melax
2. Quadratic error metric QEM by Garland & Heckbert
I finished coding the the above cost functions and associated the edge cost value between vertex Pi all in its connected vertices Qj
Next, I pick the edge with minimum edge cost, I want to collapse it using any CGAL method that operate on 3D Polyhedron mesh.
I consulted the CGAL Manual I see these options :
1. CGAL::Euler::edge_collapse which needs the mesh to be converted to a boost graph ( not clear how to do that )
2. Use Surface mesh simplification package ( but how to provide to with my own cost function)
Please advise on how to proceed with edge collapse operations ?
Best Regards to CGAL-ers
Hussein
Hussein
- [cgal-discuss] How to do Edge collapse on Polyhedron_3 using user defined cost function, Hussein Almashouq, 05/13/2015
- Re: [cgal-discuss] How to do Edge collapse on Polyhedron_3 using user defined cost function, Sebastien Loriot (GeometryFactory), 05/14/2015
- [cgal-discuss] Is there any method to generate an oriented bounding box, , 05/17/2015
- Re: [cgal-discuss] Is there any method to generate an oriented bounding box, Sebastien Loriot (GeometryFactory), 05/19/2015
- Re: [cgal-discuss] Is there any method to generate an oriented bounding box, Renato Silveira, 05/19/2015
