- To:
- Subject: Re: [cgal-discuss] CGAL-Bindings (Python): Mesh_3 examples
- Date: Fri, 22 May 2015 11:26:34 +0200
The only thing that is missing is the mesh domain class (similar to the one define in Mesh_domains.h) that can handle segmented images.
Then you need to update the interface file and duplicate the calls to
declare_global_functions_domain and declare_global_functions_domain_criteria to be used with this mesh domain.
Sebastien.
PS:
The dedicated mailing list for cgal-bindings is
On 05/21/2015 11:21 AM, Joaquin Correa wrote:
Hi folks, is there a cgal-python-bindings implementation for Mesh_3
examples, particularly
http://doc.cgal.org/latest/Mesh_3/Mesh_3_2mesh_3D_image_8cpp-example.html?
I've been trying to get started on it but it seems that not all classes
are exposed via swig,
|Exact_predicates_inexact_constructions_kernel| and |Mesh_Domain| have
to be defined but are not part of the |CGAL.CGAL_Mesh_3| module. Thank you.
mesh_3D_image.cpp:
| #include <CGAL/Exact_predicates_inexact_constructions_kernel.h>
#include <CGAL/Mesh_triangulation_3.h>
#include <CGAL/Mesh_complex_3_in_triangulation_3.h>
#include <CGAL/Mesh_criteria_3.h>
#include <CGAL/Labeled_image_mesh_domain_3.h>
#include <CGAL/make_mesh_3.h>
#include <CGAL/Image_3.h>
// Domain
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Labeled_image_mesh_domain_3<CGAL::Image_3,K> Mesh_domain;
// Triangulation
#ifdef CGAL_CONCURRENT_MESH_3
typedef CGAL::Mesh_triangulation_3<
Mesh_domain,
CGAL::Kernel_traits<Mesh_domain>::Kernel, // Same as sequential
CGAL::Parallel_tag // Tag to activate
parallelism
>::typeTr;
#else
typedef CGAL::Mesh_triangulation_3<Mesh_domain>::typeTr;
#endif
typedef CGAL::Mesh_complex_3_in_triangulation_3<Tr> C3t3;
// Criteria
typedef CGAL::Mesh_criteria_3<Tr> Mesh_criteria;
// To avoid verbose functionand named parameters call
using namespace CGAL::parameters;
int main()
// Loads image
CGAL::Image_3 image;
image.read("data/liver.inr.gz");
// Domain
Mesh_domain domain(image);
// Mesh criteria
Mesh_criteria criteria(facet_angle=30, facet_size=6,
facet_distance=4,
cell_radius_edge_ratio=3, cell_size=8);
// Meshing
C3t3 c3t3= CGAL::make_mesh_3<C3t3>(domain, criteria);
// Output
std::ofstream medit_file("out.mesh");
c3t3.output_to_medit(medit_file);
return 0;
- [cgal-discuss] CGAL-Bindings (Python): Mesh_3 examples, Joaquin Correa, 05/21/2015
- Re: [cgal-discuss] CGAL-Bindings (Python): Mesh_3 examples, Sebastien Loriot (GeometryFactory), 05/22/2015
