cgal-discuss - Re: [cgal-discuss] Assertion violation in refine_CGAL::Delaunay_mesh_2 using CGAL::Exact_predicates_inexact_constructions_kernel
  • To:
  • Subject: Re: [cgal-discuss] Assertion violation in refine_CGAL::Delaunay_mesh_2 using CGAL::Exact_predicates_inexact_constructions_kernel
  • Date: Fri, 22 May 2015 11:33:18 +0200
On 05/22/2015 11:30 AM, Renato Silveira wrote:
Thank you! I will try it!
The problem with CGAL::Exact_predicates_exact_constructions_kernel is
that the programs consumes all the memory and than crash. The problem
with points very close to each other can cause this behavior?
Note that there is no _sqrt here (which is not needed for CDT only).
Sebastien.
Thanks
On Fri, May 22, 2015 at 6:00 AM, Sebastien Loriot (GeometryFactory)
<mailto:>>
wrote:
It might be that you have two points really close to each other
after the self-intersection removal.
Maybe you should first run the polyline simplification algorithm:
http://doc.cgal.org/latest/Polyline_simplification_2/index.html#Chapter_2D_Polyline_simplification
It would definitely help if you can share a minimal example showing
the issue.
For compute_subcurves, you should use
CGAL::Exact_predicates_exact_constructions_kernel (EPECK) as Kernel.
Note also that you can compute the self-intersection inside a CDT
if intersection tag allows it. It will be safer to use EPECK too
in this case.
Sebastien.
On 05/22/2015 09:36 AM, Renato Silveira wrote:
Hi,
I'm trying to refine a Deluanay triangulation using
CGAL::refine_Delaunay_mesh_2. I'm using the kernel definitions:
typedef CGAL::Exact_predicates_inexact_constructions_kernelK;
typedef CGAL::Triangulation_vertex_base_2<K>Vb;
typedef CGAL::Delaunay_mesh_face_base_2<K>Fb;
typedef CGAL::Triangulation_data_structure_2<Vb, Fb>Tds;
typedef CGAL::Exact_predicates_tagItag;
typedef CGAL::Constrained_Delaunay_triangulation_2<K, Tds, Itag>CDT;
typedef CGAL::Delaunay_mesh_size_criteria_2<CDT>Criteria;
typedef CGAL::Delaunay_mesher_2<CDT, Criteria>Mesher;
typedef CDT::Vertex_handleVertex_handle;
typedef CDT::PointCDT_Point;
Initially, my CDT constraints auto-intersects, but I eliminate
intersections using *CGAL::compute_subcurves *(using kernel
*CGAL::Quotient<CGAL::MP_Float>*) on the constraints before the
triangulation, as shown in attached figure (I thought it could
solves
the problem).
I got a valid CDT triangulation (as shown in the attached
figure) but
when I try to refine the CDT, using the method:
*CGAL::refine_Delaunay_mesh_2(...);*
with the criteria:
*Criteria(0.125, 25.0f)*
I got this assert violation:
/*terminate called after throwing an instance of
'CGAL::Assertion_exception' */
/* what(): CGAL ERROR: assertion violation! */
/*Expr: n == zone.fh */
/*File: /usr/local/include/CGAL/Mesh_2/Refine_edges.h */
/*Line: 438 */
I think constraint intersections can appear again when I convert
points
from kernel *CGAL::Quotient<CGAL::MP_Float>* to kernel
*CGAL::Exact_predicates_inexact_constructions_kernel*. If I
could run
*CGAL::Delaunay_mesher_2* with kernel
*CGAL::Quotient<CGAL::MP_Float>* I
will not have any intersections (I think).
I don't know if the problem is with my constraints or with the
mesher.
Any ideas what I should try?
PS:
- Using only the boundary as CDT constraints, everything works
fine (as
shown in attached figure).
- I also tested everything with
Exact_predicates_exact_constructions_kernel_with_sqrt kernel, with
CGAL::Exact_intersections_tag but it takes so much time and then
it run
out of memory with the message: "GNU MP: Cannot allocate memory
(size=25186388)".
Thank you in advance
Renato
*/Renato Silveira
Ph.D. in Computer Science
Informatics Institute - UFRGS
Porto Alegre - RS - Brazil
http://www.inf.ufrgs.br/~rsilveira
*/Renato Silveira
