- To:
- Subject: Re: [cgal-discuss] polyhedron_ex_parameterization
- Date: Fri, 29 May 2015 12:00:21 +0200
Hi Hardik, Simple_parameterization.cpp and polyhedron_ex_parameterization.cpp do not use the same data structures to store the (u, v) values. You need to adapt the code when you copy code from Simple_parameterization.cpp to polyhedron_ex_parameterization.cpp. polyhedron_ex_parameterization.cpp stores the mesh in the class Polyhedron_ex defined in Polyhedron_ex.h. I think that the next code should work: double u = pVertex->halfedge()->u(); double v = pVertex->halfedge()->v();
Best regards, Laurent Saboret Transvalor/MINES Paristech Le 28/05/2015 23:07, Hardik Kabaria a
écrit :
Hi Laurent,
Simple_parametrization.cpp access (uv) as follows:
Polyhedron::Vertex_const_iterator pVertex;
for (pVertex = mesh.vertices_begin();
pVertex != mesh.vertices_end();
pVertex++)
// (u,v) pair is stored in any halfedge
double u =
mesh_adaptor.info(pVertex->halfedge())->uv().x();
double v =
mesh_adaptor.info(pVertex->halfedge())->uv().y();
std::cout << "(u,v) = (" << u <<
"," << v << ")" << std::endl;
I get the following compiler error when I try the same:
/usr/local/soft/CGAL-4.2/examples/Surface_mesh_parameterization/polyhedron_ex_parameterization.cpp:517:33:
error: no member named 'info' in
'Parameterization_polyhedron_adaptor_ex'
double u =
polyehdron_ex_parametrization uses: #include
"Parameterization_polyhedron_adaptor_ex.h"
and I could not find info() option in it.
Am I missing something ?
Thanks!
Hardik
On May 26, 2015, at 12:59 AM, Laurent Saboret <>
wrote:
Hardik
Kabaria
Ph.D.
Candidate
Department
of Mechanical Engineering
Stanford
University
- [cgal-discuss] polyhedron_ex_parameterization, Hardik Kabaria, 05/26/2015
- Re: [cgal-discuss] polyhedron_ex_parameterization, Laurent Saboret, 05/26/2015
- Re: [cgal-discuss] polyhedron_ex_parameterization, Hardik Kabaria, 05/28/2015
- Re: [cgal-discuss] polyhedron_ex_parameterization, Laurent Saboret, 05/29/2015
