cgal-discuss - [cgal-discuss] Manifold surfaces from label images
  • To:
  • Subject: [cgal-discuss] Manifold surfaces from label images
  • Date: Mon, 15 Jun 2015 21:49:59 +0200
Hi
I read about the make_surface_mesh function and looked at the examples.
Is it possible to generate multi-domain surfaces from label images (segmentations) using make_surface_mesh?
If possible, the subdomain surfaces should be manifold. The documentation mentions an "undocumented" feature, which might provide this functionality.
I have an image segmentation of the human body and would like to generate surfaces, which are compatible (i.e. share triangles between domains) and manifold.
Previously I have generated tetrahedral meshes using make_mesh_3 and extracted the facets and subdomain interfaces. Unfortunately, there is no way to enforce subdomain surfaces to be manifold in this method.
Thanks for any ideas
Bryn
  • [cgal-discuss] Manifold surfaces from label images, Bryn Lloyd, 06/15/2015
