- To:
- Subject: Re: [cgal-discuss] Note of thanks re. polyhedral meshing
- Date: Thu, 18 Jun 2015 14:19:55 +0200
Le Thursday 18 June 2015 11:59:35 Phil Weir a écrit :
> > Do you think that some of your implementation is generic enough that it
> > could be contributed to CGAL?
> Ideally - this specific class is a very short alteration of
> Labeled_image_domain_3, so nothing too exciting, but modulo a little
> documentation and bug-checking (on-going), should be reusable generally.
> Apologies if this has been implemented upstream recently and I haven't
> spotted it, but the MSH export, with physical (volumetric+boundary)
> subdomains, may be useful also.
It's up to you (or to the authors of the code if it is not yours). Depending
on the size of the contribution, that might require a Copyright Assignment
Agreement, but contributions like a few lines of modification, or for a new
export function to the MSH format, I do not think that is required.
Laurent Rineau, PhD
- [cgal-discuss] Note of thanks re. polyhedral meshing, Phil Weir, 06/17/2015
- Re: [cgal-discuss] Note of thanks re. polyhedral meshing, Laurent Rineau (CGAL/GeometryFactory), 06/18/2015
- Re: [cgal-discuss] Note of thanks re. polyhedral meshing, Phil Weir, 06/18/2015
