- To:
- Subject: Re: [cgal-discuss] CGAL 4.5.1 install fails on Solaris 10 Sparc 64 bit
- Date: Sat, 20 Jun 2015 13:18:30 -0700 (PDT)
Sebastien Loriot (GeometryFactory) wrote
> Have a look at:
> See also "/opt/CGAL-4.5.1/CMakeFiles/CMakeOutput.log".
> See also "/opt/CGAL-4.5.1/CMakeFiles/CMakeError.log".
> they might contain more information that will be helpful to understand
> the issue. Might be that you don't have write permission in /opt for
> example.
Write permission isn't the problem. I'm running this as root.
Here are the log files. Does this mean anything to you?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/CGAL-4-5-1-install-fails-on-Solaris-10-Sparc-64-bit-tp4660404p4660929.html
- Re: [cgal-discuss] CGAL 4.5.1 install fails on Solaris 10 Sparc 64 bit, Michele31415, 06/20/2015
