Re: [cgal-discuss] Linear cell complex: Segmentation fault while accessing vertex of a 2-cell
- To:
- Subject: Re: [cgal-discuss] Linear cell complex: Segmentation fault while accessing vertex of a 2-cell
- Date: Thu, 25 Jun 2015 15:48:46 +0200
Le 25/06/2015 15:19, Pranav a écrit :
Hi Guilliame,
Guillaume Damiand wrote
Hi pravav,Specifically, the segmentation fault occurs at this line
Without more code, it is impossible for me to suggest anything...
<https://github.com/pranavkantgaur/CDTGenerator/blob/TDD/src/cdtGen.cpp#L1295>
, but the code is a mess so meanwhile, I am trying to create a minimal code
example demonstrating this problem.
It is once again the same problem:
in the loop line 1521, you iterate throu the lcc, and inside this loop removes a cell (line 1526) which invalidates the first loop.
Here the solution is, as previously, push in a container one dart per cell to remove, and in a second loop iterate through this container to apply remove_cell.
A last remark: if you are in 3D and if you want to have one dart perSegmentation fault disappeared using Dart_of_orbit_range as you suggested.
each vertex of a given face, a better possibility is to use:
for (LCC::Dart_of_orbit_range<1>::iterator pHandleBegin =
lcc.darts_of_orbit<1>(fHandle).begin(), pHandleEnd =
lcc.darts_of_orbit<1>(fHandle).end(); pHandleBegin !=
pHandleEnd; pHandleBegin++)
It is just lucky ;)
You can do the same optimisation line 1302.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Linear-cell-complex-Segmentation-fault-while-accessing-vertex-of-a-2-cell-tp4660939p4660941.html
Guillaume DAMIAND
CNRS - LIRIS UMR 5205
Université Claude Bernard
Bâtiment Nautibus (710)
43 Boulevard du 11 Novembre 1918
69622 Villeurbanne Cedex (France)
Tél: +33 (0)4.72.43.14.34 Fax: +33 (0)4.72.43.15.36
Mail:
Web: http://liris.cnrs.fr/guillaume.damiand/
smime.p7s
Description: Signature cryptographique S/MIME
- [cgal-discuss] Linear cell complex: Segmentation fault while accessing vertex of a 2-cell, Pranav, 06/25/2015
- Re: [cgal-discuss] Linear cell complex: Segmentation fault while accessing vertex of a 2-cell, Guillaume Damiand, 06/25/2015
- Re: [cgal-discuss] Linear cell complex: Segmentation fault while accessing vertex of a 2-cell, Pranav, 06/25/2015
