- To: cgal-discuss <>
- Subject: Re: [cgal-discuss] Slicing/splitting/cutting polyhedral meshes
- Date: Tue, 30 Jun 2015 11:13:27 -0400
Hi Aamir. Yes, I did some changes to make it work, but I only had partial success. For what I was trying to solve, the slicer algorithm that Sebastian passed me gave me a good headstart. I had to do some modifications but in the end I got it working. What are you trying to do? In my case I was trying to construct cut-cells for a fluid-solver, so I had only to compute multiple plane crossings (slices) and add them back to the original mesh.
Vinicius C. Azevedo.
On Tue, Jun 30, 2015 at 5:36 AM, Aamir <> wrote:
Vinicius Azevedo wrote
> I've changed all Vertex() constructors from
> halfedgeDS_cut_component
> to Vertex(pred.getPlane().projection(h->vertex()->point())). I've also
> made
> some few adjustments on the polyhedron_cut_plane_3. If anyone is
> interested
> I can post the full modified code.
Can you please share those changes which you made for it to work.
Regards
Aamir
View this message in context: http://cgal-discuss.949826.n4.nabble.com/Slicing-splitting-cutting-polyhedral-meshes-tp4660731p4660953.html
- Re: [cgal-discuss] Slicing/splitting/cutting polyhedral meshes, Aamir, 06/29/2015
- <Possible follow-up(s)>
- Re: [cgal-discuss] Slicing/splitting/cutting polyhedral meshes, Aamir, 06/30/2015
- Re: [cgal-discuss] Slicing/splitting/cutting polyhedral meshes, Vinicius Azevedo, 06/30/2015
