cgal-discuss - Re: [cgal-discuss] Slicing/splitting/cutting polyhedral meshes
  • To: cgal-discuss <>
  • Subject: Re: [cgal-discuss] Slicing/splitting/cutting polyhedral meshes
  • Date: Sun, 5 Jul 2015 11:12:48 -0400
Whats the red line? You plotted yourself? That's odd. It worked for me:
https://dl.dropboxusercontent.com/u/5919734/bunnyW1.png
I would guess that is the part that is projecting the points into the mesh (pred.plane().projection(g->vertex()->point())). Can you check that with an explicit projection with the desired plane (zeroing the components that you will not use)?
Vinicius C. Azevedo.
On Sat, Jul 4, 2015 at 12:11 PM, Aamir <> wrote:
Vinicius Azevedo,
Thank you very much for sharing code. I've used it in my project, but
unfortunately, couldn't received desired results.
<http://cgal-discuss.949826.n4.nabble.com/file/n4660971/MeshCutter.png>
Have you also faced this issue or any Idea, how to deal with this problem?
Regards
Aamir
View this message in context: http://cgal-discuss.949826.n4.nabble.com/Slicing-splitting-cutting-polyhedral-meshes-tp4660731p4660971.html
