- To:
- Subject: Re: [cgal-discuss] Straight Skeleton - Thread Safe
- Date: Fri, 10 Jul 2015 10:52:33 +0200 (CEST)
On Fri, 10 Jul 2015, Marcel wrote:
i have some trouble with your Straight Skeleton implementation. I call
several independent instances of the straight skeleton implementation in
parallel. Unfortunately, with a parallel execution, my program crashes
with a segmentation fault, double free or corruption or similar errors.
My code basically looks like the following.
using CGAL;
typedef Simple_cartesian<Gmpq> Kernel;
Can you try with mpq_class instead of Gmpq?
std::vector<Polygon_2<Kernel>> polygons; // non empty set of polygons ;)
Can the different polygons have some point coordinates in common?
#pragma omp parallel for
for (size_t i = 0; i < polygons.size(); ++i) {
auto skeleton =
create_interior_straight_skeleton_2<Polygon_2<Kernel>,
Kernel>(polygons[i],c);
A serial execution of my code works flawlessly. Thus, putting the
straight skeleton computation in a critical section works as well. I've
tried to define the CGAL_HAS_THREADS macro but as far as I can tell,
this has no effect. I have incorporated the patch presented in [1] but
this does not work as well (Note that I am using CGAL 4.6.1).
Hmm, if you tried that patch then it is probably not the issue I was thinking about, but it is still useful to check.
Is this a known issue? Is there a work around?
Marc Glisse
- [cgal-discuss] Straight Skeleton - Thread Safe, Marcel, 07/10/2015
- Re: [cgal-discuss] Straight Skeleton - Thread Safe, Marc Glisse, 07/10/2015
