Re: [cgal-discuss] Linear Cell complex: Spliting an segment by inserting a point
- To:
- Subject: Re: [cgal-discuss] Linear Cell complex: Spliting an segment by inserting a point
- Date: Mon, 13 Jul 2015 12:24:31 +0200
Le 13/07/2015 09:43, Pranav a écrit :
Hi Guillaume,
Further I would like to know if while inserting the vertex on a segment I
want to split the the facet containing that segment then should I use
insert_point_in_cell<2>(dartHandleToSegment, point) ?
No. insert_point_in_cell<2> inserts a point in the middle of the 2-cell. For a triangle, it will be split in 3 triangles.
For example, say for a triangle represented by 2-cell, I want to insert a
vertex on one of its edge and it should be inserted in such a way so that
this triangle is split into 2 triangles.
To do this operation, you must first insert a point in the edge, then insert an edge between the new point and the third point of the triangle.
Guillaume
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Linear-Cell-complex-Spliting-an-segment-by-inserting-a-point-tp4660541p4661005.html
Guillaume DAMIAND
CNRS - LIRIS UMR 5205
Université Claude Bernard
Bâtiment Nautibus (710)
43 Boulevard du 11 Novembre 1918
69622 Villeurbanne Cedex (France)
Tél: +33 (0)4.72.43.14.34 Fax: +33 (0)4.72.43.15.36
Mail:
Web: http://liris.cnrs.fr/guillaume.damiand/
smime.p7s
Description: Signature cryptographique S/MIME
- Re: [cgal-discuss] Linear Cell complex: Spliting an segment by inserting a point, Pranav, 07/13/2015
- Re: [cgal-discuss] Linear Cell complex: Spliting an segment by inserting a point, Guillaume Damiand, 07/13/2015
