cgal-discuss - [cgal-discuss] Polyhedral intersections between cells of two different 3D meshes
  • To:
  • Subject: [cgal-discuss] Polyhedral intersections between cells of two different 3D meshes
  • Date: Fri, 31 Jul 2015 17:04:37 +0200
Hello!
   I’m working on an algorithm where I need to determinate the polyhedral intersections between the cells (tetrahedrons) of two different 3D meshes. Searching a bit on the mailing list’s archives, I’ve found some pointers on how to find these intersections [1] with CGAL, but I still have to filter out the polygonal intersections. Is there any method inside CGAL that tests if a set of points are all inside the same plane? This is not hard to do by hand, but I’d wager that if CGAL has such a method, it would be more efficient than my own code.
Thanks in advance,
Thiago
[1] http://cgal-discuss.949826.n4.nabble.com/Intersection-of-two-CONVEX-3D-polyhedrons-td4564202.html
  • [cgal-discuss] Polyhedral intersections between cells of two different 3D meshes, Thiago Milanetto Schlittler, 07/31/2015
