cgal-discuss - Re: [cgal-discuss] Polyhedral intersections between cells of two different 3D meshes
  • To:
  • Subject: Re: [cgal-discuss] Polyhedral intersections between cells of two different 3D meshes
  • Date: Mon, 03 Aug 2015 08:22:35 +0200
Plane_3::has_on_positive_side ?
http://doc.cgal.org/latest/Kernel_23/classCGAL_1_1Plane__3.html#a2ca90cac980833ff38dd12dcb9858baf
Sebastien.
On 07/31/2015 05:04 PM, Thiago Milanetto Schlittler wrote:
Hello!
I’m working on an algorithm where I need to determinate the
*polyhedral *intersections between the cells (tetrahedrons) of two
different 3D meshes. Searching a bit on the mailing list’s archives,
I’ve found some pointers on how to find these intersections [1] with
CGAL, but I still have to filter out the polygonal intersections. Is
there any method inside CGAL that tests if a set of points are all
inside the same plane? This is not hard to do by hand, but I’d wager
that if CGAL has such a method, it would be more efficient than my own code.
Thanks in advance,
Thiago
[1]
http://cgal-discuss.949826.n4.nabble.com/Intersection-of-two-CONVEX-3D-polyhedrons-td4564202.html
  • Re: [cgal-discuss] Polyhedral intersections between cells of two different 3D meshes, Sebastien Loriot (GeometryFactory), 08/03/2015
