- To:
- Subject: Re: [cgal-discuss] Combinatorial maps: assertion error: this->mmap->is_marked
- Date: Sun, 09 Aug 2015 20:20:47 +0200
Hi,
I think the problem could be that you remove twice a same 2-cell.
Indeed, in the first loop (line 1743) you push one dart per 2-cell to test; but in the second loop (line 1758) you iterate through all the faces of each volume having one dart in the vector.
Thus probably in the second loop you reach to a face which has one of its dart later in the vector.
This is only a supposition after a quick look at your code. You need to try to debug your code, by adding assertion and by developing some functions allowing to add debug test.
For example you can develop a function which tests, just before that you remove a 2-cell, that all the other darts in the vector do not belong to the same 2-cell than the one removed. This function will help to solve your problem.
Good luck
Guillaume
Le 05/08/2015 11:35, Pranav a écrit :
Hi,
Do I need to add more information to this question? Unfortunately, as of
now, I am unable to make a minimal code for demonstrating this problem.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Combinatorial-maps-assertion-error-this-mmap-is-marked-tp4661029p4661047.html
Guillaume DAMIAND
CNRS - LIRIS UMR 5205
Université Claude Bernard
Bâtiment Nautibus (710)
43 Boulevard du 11 Novembre 1918
69622 Villeurbanne Cedex (France)
Tél: +33 (0)4.72.43.14.34 Fax: +33 (0)4.72.43.15.36
Mail:
Web: http://liris.cnrs.fr/guillaume.damiand/
smime.p7s
Description: Signature cryptographique S/MIME
- Re: [cgal-discuss] Combinatorial maps: assertion error: this->mmap->is_marked, Pranav, 08/05/2015
- Re: [cgal-discuss] Combinatorial maps: assertion error: this->mmap->is_marked, Guillaume Damiand, 08/09/2015
- Re: [cgal-discuss] Combinatorial maps: assertion error: this->mmap->is_marked, Pranav, 08/18/2015
- Re: [cgal-discuss] Combinatorial maps: assertion error: this->mmap->is_marked, Guillaume Damiand, 08/18/2015
