cgal-discuss - Re: [cgal-discuss] 3D Mesh Generation from CGAL::Polyhedral_mesh_domain_with_features_3
  • To:
  • Subject: Re: [cgal-discuss] 3D Mesh Generation from CGAL::Polyhedral_mesh_domain_with_features_3
  • Date: Thu, 13 Aug 2015 00:12:53 -0700 (PDT)
Sebastien, thanks for your reply. Based on your suggestion, I relinked the
CGAL libs to ensure I was using the correct one. I also reinstalled CGAL
with both MacPorts and Homebrew to make sure that wasn't the issue. I'm
still getting the same linking errors during compilation. Please let me know
if you think of anything else that could be causing this problem...
# Project created by QtCreator 2015-06-26T11:08:37
QT += core gui opengl
QT += testlib
greaterThan(QT_MAJOR_VERSION, 4): QT += widgets
TARGET = projectV1
TEMPLATE = app
SOURCES += main.cpp\
mainwindow.cpp \
glwidget.cpp \
testqstring.cpp \
../../../../Qt/Examples/Qt-5.4/widgets/graphicsview/boxes/trackball.cpp
camera.cpp \
objload.cpp
HEADERS += mainwindow.h \
glwidget.h \
camera.h \
objload.h \
myitems.h
FORMS += mainwindow.ui
# CGAL LIBRARY
macx: LIBS += -L$$PWD/../../../../../../opt/local/lib/ -lCGAL
INCLUDEPATH += $$PWD/../../../../../../opt/local/include
DEPENDPATH += $$PWD/../../../../../../opt/local/include
# CGAL CORE LIBRARY
macx: LIBS += -L$$PWD/../../../../../../opt/local/lib/ -lCGAL_Core.11
# CGAL IMAGE IO LIBRARY
macx: LIBS += -L$$PWD/../../../../../../opt/local/lib/ -lCGAL_ImageIO
# BOOST THREAD LIBRARY
macx: LIBS += -L$$PWD/../../../../../../opt/local/lib/ -lboost_thread-mt
# BOOST SYSTEM LIBRARY
macx: LIBS += -L$$PWD/../../../../../../opt/local/lib/ -lboost_system-mt
# GMP LIBRARY
macx: LIBS += -L$$PWD/../../../../../../opt/local/lib/ -lgmp
# MPFR LIBRARY
macx: LIBS += -L$$PWD/../../../../../../opt/local/lib/ -lmpfr
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/3D-Mesh-Generation-from-CGAL-Polyhedral-mesh-domain-with-features-3-tp4661063p4661068.html
