- To:
- Subject: Re: [cgal-discuss] Smooth external surface when meshing 3D images
- Date: Fri, 14 Aug 2015 18:36:24 +0200
Hi, the feature preservation can indeed preserve only 0D and 1D features. However, the polyline that makes the junction between the red, blue, and empty areas is a 1D feature. If you want to preserve it, you need to give it as a polyline to the feature protection function. About surfaces, they cannot be preserved exactly, but all boundary vertices of the output mesh belong to the surface of your input. For an image, the minimum edge length you choose for the surface should be larger than the voxel size, otherwise the output mesh will follow the "steps" of the boundary. Best, -- Jane Tournois, PhD R&D Engineer at GeometryFactory http://www.geometryfactory.com/ Le 14/08/2015 15:49, Andrew Crozier a
écrit :
Hi, |
Description: PNG image
- [cgal-discuss] Smooth external surface when meshing 3D images, Andrew Crozier, 08/14/2015
- Re: [cgal-discuss] Smooth external surface when meshing 3D images, Jane Tournois, 08/14/2015
