- To:
- Subject: Re: [cgal-discuss] Merge polylines
- Date: Mon, 24 Aug 2015 16:44:18 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23:JnzkHBDjJmYFvtBl6LFDUyQJP3N1i/DPJgcQr6AfoPdwSP74ocbcNUDSrc9gkEXOFd2CrakU0KyL7uu/BSQp2tWojjMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpQAbFhi3DwdpPOO9QteU1JTskb3vsMKPKyxzxxODIppKZC2sqgvQssREyaBDEY0WjiXzn31TZu5NznlpL1/A1zz158O34YIxu38I46FppIZ8VvDxcK08CLBZFz87KHsd5cvxtBCFQxHcyGEbVzA8iAtOSyzB6wD2FsP1tizrusJ8xCiBe8DqTaJyUjT0vPQjcwPhlCpSb21xy2rQkMEl1K8=
Yes and no. It would depend on the tolerance. I would also like to be able to mesh with the features you displayed in the first image.
The "tolerance" could depend on the "edge size" protected edges.
My overall goal is to generate a mesh with 1D features. I want the mesher to run successfully and not stop because of the assertion I mentioned.
I think if I pre-process the protected edges somehow (e.g. merge), the mesher will manage to preserve the features and run successfully.
On 8/24/2015 4:29 PM, Sebastien Loriot (GeometryFactory) wrote:
On 08/24/2015 03:31 PM, Bryn Lloyd wrote:
Thanks for looking at the data. Yes, you extracted the data correctly.
I am working on a few "test cases", one where the cubes are aligned and
one where the cubes are nearly aligned, and maybe touching...
Thanks
Bryn
OK so in your context, a polyline is a set of protected edges, correct?
Would you expect to get the input polyhedra modified as displayed in the picture attached?
Sebastien.
On 8/24/2015 3:12 PM, Sebastien Loriot (GeometryFactory) wrote:
Thanks for the data.
That's not what I expected when you mentioned almost identical polylines.
Did I extract correctly the data?
Thanks,
Sebastien.
On 08/24/2015 02:05 PM, Bryn Lloyd wrote:
Dear Sebastien
I attached the surface and polylines as code sample (C-arrays), but can
also provide other formats if that is easier for you.
Thanks & best regards
On 8/24/2015 1:11 PM, Bryn Lloyd wrote:
Thanks. I will send the data just now.
There error I am getting when I don't merge or pre-process the feature
lines is in
Protect_edges_sizing_field.h
-> smart_insert_point
-> line 550
CGAL_assertion( minimal_size_ >0 || sq_d > 0 );
What is the meaning of this code, i.e. what is 'minimal_size_' and
what is 'sq_d'? How can I avoid this condition?
On 8/24/2015 10:23 AM, Sebastien Loriot (GeometryFactory) wrote:
I have some experimental code that might be good enough in your case.
Could you send me some representative data sample so that I can give
it a try?
Thanks,
Sebastien.
On 08/21/2015 09:17 AM, Bryn Lloyd wrote:
Dear list
Is there some way in CGAL to merge nearly identical/overlapping 3D
polylines?
For instance if I would have two polylines of the same circle but
faceted slightly differently: is there I way I could with a specified
(distance error) tolerance, merge these 2 polylines into one or
detect
that they are "identical"?
A more complicated example is two squares sharing one edge, but
faceted
differently along the shared edge.
The goal of this operation is to remove problematic 1D features
for 3D
mesh generation.
Bryn
On 20.08.2015 16:55, Bryn Lloyd wrote:
Hi CGAL users and devs
I am trying to use make_mesh_3 with feature lines enabled.
I am creating multi-domain meshes with domains defined via surface
meshes (I derive from CGAL::Labeled_mesh_domain_3, see below).
Using angle and length criteria I extract feature edges from each
surface and add these via
/// CGAL::Bbox_3 box = ...//;//
/ domain_wrapper_type domain_wrapper(my_domains, progress);//
// Mesh_domain_with_features domain(domain_wrapper, box);//
// if( m_EnablePolylineFeatures ) //{//
// domain.add_features(polylines.begin(), polylines.end());//
Mesh_criteria criteria(edge_size=m_EdgeSize,
facet_angle=m_FacetAngle, facet_size=sizing_wrapper,
facet_distance=m_FacetDistance,
cell_radius_edge=m_CellRatio, cell_size=m_CellSize );
////auto c3t3 = CGAL::make_mesh_3<C3t3>(domain, criteria,
no_lloyd(),
no_odt(), perturb(), exude());
/Sometimes the mesh generation fails when edges are too close,
e.g. if
they are (partially) overlapping or closer than the chosen
'/edge_size'/.
How can I robustly detect (nearly) overlapping edges/feature
lines in
order to remove/cleanup these lines?
Thanks for any ideas,
Bryn
/ template< class BGT,class Wrapper=CLabelFunction<BGT> >//
// class CLabeledMeshDomain : public
CGAL::Labeled_mesh_domain_3<Wrapper, BGT>//
// public://
// typedef CGAL::Labeled_mesh_domain_3<Wrapper, BGT> Base;//
// typedef typename Base::Sphere_3 Sphere_3;//
// typedef typename BGT::FT FT;//
// typedef BGT Geom_traits;//
// typedef CGAL::Bbox_3 Bbox_3;//
// CLabeledMeshDomain(const Wrapper& wrapper, const Bbox_3&
bbox, const FT& error_bound = FT(1e-3))//
// : Base(wrapper,bbox,error_bound) {}//
// virtual ~CLabeledMeshDomain() {}//
// private://
// // Disabled copy constructor & assignment operator//
// typedef CLabeledMeshDomain<BGT> Self;//
// CLabeledMeshDomain(const Self& src);//
// Self& operator=(const Self& src);//
- [cgal-discuss] Make mesh with features: feature lines duplicated, overlapping or very close, Bryn Lloyd, 08/20/2015
- [cgal-discuss] Merge polylines, Bryn Lloyd, 08/21/2015
- Re: [cgal-discuss] Merge polylines, Sebastien Loriot (GeometryFactory), 08/24/2015
- Re: [cgal-discuss] Merge polylines, Bryn Lloyd, 08/24/2015
- Re: [cgal-discuss] Merge polylines, Laurent Rineau (CGAL/GeometryFactory), 08/25/2015
