[cgal-discuss] RGBD Field of View and mesh intersection surface (Occlusion culling)
- To:
- Subject: [cgal-discuss] RGBD Field of View and mesh intersection surface (Occlusion culling)
- Date: Sat, 29 Aug 2015 13:30:52 -0700 (PDT)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
- Ironport-phdr: 9a23:EG0a4xyoAaOeb03XCy+O+j09IxM/srCxBDY+r6Qd0e8QIJqq85mqBkHD//Il1AaPBtWArawUwLOK7ujJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6kO74TNaIBjjLw09fr2zQd6JyZrnnLnuptX6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD88QIrJARFPyiN+RjFeQZX3waNDU+68Tv8BXCVgCS/WA0U2MMkxMODRKWwgv9W8Lruy32v6IpwiCcMcSwRLQxUDii6LptYBDtgSYDcTU+9TeE2YRLkKtHrUf49FREyInObdTObKJz
I'm trying to get the intersection surface area between an RGBD sensor FOV
and a mesh model since I want to use these surfaces to fasten the
development of a reconstruction algorithm.
It is similar to the intersection surface of two models as it is shown in
the following image:
<http://cgal-discuss.949826.n4.nabble.com/file/n4661115/mxS4enXFjmWuyILduEG7SHjRQTUOOJDKC3-kbVTOGLc.jpeg>
, but instead of the sphere, I have the FOV (Quadrahedron shape) and instead
of the cube model, I have another model shape,
The blue part of the cube surface shown in the third part of the image is
the intersection surface needed to be found.
The result should be the visible surface in the Field of view similar to the
concept of occlusion culling
Is there a function in CGAL that can find this visible surface ?
Thanks
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/RGBD-Field-of-View-and-mesh-intersection-surface-Occlusion-culling-tp4661115.html
- [cgal-discuss] RGBD Field of View and mesh intersection surface (Occlusion culling), randa, 08/29/2015
