- To: "" <>
- Subject: [cgal-discuss] Attaching Data to dD Delaunay Triangulation Vertices
- Date: Tue, 8 Sep 2015 08:53:49 +0200
- Accept-language: en-US, de-CH
- Acceptlanguage: en-US, de-CH
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:+TnvgRWfS7/xW3rEHaaLOyhvJDbV8LGtZVwlr6E/grcLSJyIuqrYZhOGt8tkgFKBZ4jH8fUM07OQ6PC8HzVZqs7a+Fk5M7VyFDY9wf0MmAIhBMPXQWbaF9XNKxIAIcJZSVV+9Gu6O0UGUOz3ZlnVv2HgpWVKQka3CwN5K6zPF5LIiIzvjqbpq8GVOlwD3GH1SIgxBSv1hD2ZjtMRj4pmJ/R54TryiVwMRd5rw3h1L0mYhRf265T41pdi9yNNp6BprJYYAu2pN5g/GPZTAz0idmw0/8b2rgLrTA2V53JaXH9c2k5DDAHBqR37RZzsqTDSt+xn2SDcM9egHp4uXjH31KxrRQXyhT1PGzc/8WzTwphchaRarRbnnBd/zpTObZu9L/FlOKjdK4BJDVFdV9pcAnQSSri3aJECWrIM
Hello
Can someone explain how user data can be stored in the Vertices of a dD
Delaunay Triangulation?
In the "delaunay_triangulation.cpp" example I tried to change the lines
const int D=5;
typedef CGAL::Epick_d< CGAL::Dimension_tag<D> > K;
typedef CGAL::Delaunay_triangulation<K> T;
to
struct MyData {
double value;
const int D = 5;
typedef CGAL::Epick_d<CGAL::Dimension_tag<D>> K;
typedef CGAL::Triangulation_data_structure<K,
CGAL::Triangulation_vertex<K, MyData>, CGAL::Triangulation_full_cell<K>> Tds;
typedef CGAL::Delaunay_triangulation<K, Tds> T;
But the first time type "T" is used, I get compiler errors that I do not
fully understand as I am not so used to work with templates:
1>C:\Program
Files\CGAL-4.6.2\include\CGAL/TDS_full_cell_default_storage_policy.h(41):
error C2027: use of undefined type 'CGAL::internal::Dimen_plus_one<Dimen>'
1> with
1> [
1> Dimen=CGAL::Epick_d<CGAL::Dimension_tag<3>>
1> ]
1> C:\Program
Files\CGAL-4.6.2\include\CGAL/Triangulation_ds_full_cell.h(60) : see
reference to class template instantiation
'CGAL::TFC_data<CGAL::internal::CC_iterator<CGAL::Compact_container<CGAL::Triangulation_vertex<TriangulationTraits,Data_,CGAL::Triangulation_ds_vertex<TDS2>>,CGAL::Default,CGAL::Default,CGAL::Default>,false>,CGAL::internal::CC_iterator<CGAL::Compact_container<CGAL::Triangulation_full_cell<TriangulationTraits,CGAL::No_full_cell_data,CGAL::Triangulation_ds_full_cell<TDS2,StoragePolicy>>,CGAL::Default,CGAL::Default,CGAL::Default>,false>,CGAL::Epick_d<CGAL::Dimension_tag<3>>,CGAL::TDS_full_cell_default_storage_policy>'
being compiled
1> with
1> [
1> TriangulationTraits=K
1> , Data_=MyData
1> ,
TDS2=CGAL::Triangulation_data_structure<K,CGAL::Triangulation_vertex<K,MyData,CGAL::Default>,CGAL::Triangulation_full_cell<K,CGAL::No_full_cell_data,CGAL::Default>>
1> , StoragePolicy=CGAL::Default
1> ]
1> C:\Program
Files\CGAL-4.6.2\include\CGAL/Triangulation_full_cell.h(34) : see reference
'CGAL::Triangulation_ds_full_cell<TDS2,StoragePolicy>' being compiled
1> with
1> [
1>
1> ]
1> C:\Program Files\CGAL-4.6.2\include\CGAL/Triangulation.h(203) :
see reference to class template instantiation
'CGAL::Triangulation_full_cell<TriangulationTraits,Data_,CGAL::Triangulation_ds_full_cell<TDS2,StoragePolicy>>'
being compiled
1> with
1> [
1> , Data_=CGAL::No_full_cell_data
1> ,
1> ]
1> C:\Program
Files\CGAL-4.6.2\include\CGAL/Delaunay_triangulation.h(41) : see reference to
'CGAL::Triangulation<DCTraits,CGAL::Triangulation_data_structure<K,CGAL::Triangulation_vertex<K,MyData,CGAL::Default>,CGAL::Triangulation_full_cell<K,CGAL::No_full_cell_data,CGAL::Default>>>'
being compiled
1> with
1> [
1> DCTraits=K
1> ]
1> src\datalandscape\LinearLandscape6D.cpp(56) : see reference
1>to class template instantiation 'CGAL::Delaunay_triangulation<K,Tds>' being
compiled C:\Program
error C2146: syntax error : missing ';' before identifier 'Dimen_plus'
1>C:\Program
1>Files\CGAL-4.6.2\include\CGAL/TDS_full_cell_default_storage_policy.h(4
1>1): error C4430: missing type specifier - int assumed. Note: C++ does not
support default-int C:\Program
Files\CGAL-4.6.2\include\CGAL/TDS_full_cell_default_storage_policy.h(42):
error C2065: 'Dimen_plus' : undeclared identifier C:\Program
error C2923: 'CGAL::internal::S_or_D_array' : 'Dimen_plus' is not a valid
template type argument for parameter 'D'
1>C:\Program
1>Files\CGAL-4.6.2\include\CGAL/TDS_full_cell_default_storage_policy.h(43):
1>C:\Program
Files\CGAL-4.6.2\include\CGAL/TDS_full_cell_default_storage_policy.h(45):
error C2079:
'CGAL::TFC_data<CGAL::internal::CC_iterator<CGAL::Compact_container<CGAL::Triangulation_vertex<TriangulationTraits,Data_,CGAL::Triangulation_ds_vertex<TDS2>>,CGAL::Default,CGAL::Default,CGAL::Default>,false>,CGAL::internal::CC_iterator<CGAL::Compact_container<CGAL::Triangulation_full_cell<TriangulationTraits,CGAL::No_full_cell_data,CGAL::Triangulation_ds_full_cell<TDS2,StoragePolicy>>,CGAL::Default,CGAL::Default,CGAL::Default>,false>,CGAL::Epick_d<CGAL::Dimension_tag<3>>,CGAL::TDS_full_cell_default_storage_policy>::vertices_'
uses undefined struct 'CGAL::internal::S_or_D_array'
1> with
1> [
1> , Data_=MyData
1> ,
1> ]
1>C:\Program
Files\CGAL-4.6.2\include\CGAL/TDS_full_cell_default_storage_policy.h(46):
error C2079:
'CGAL::TFC_data<CGAL::internal::CC_iterator<CGAL::Compact_container<CGAL::Triangulation_vertex<TriangulationTraits,Data_,CGAL::Triangulation_ds_vertex<TDS2>>,CGAL::Default,CGAL::Default,CGAL::Default>,false>,CGAL::internal::CC_iterator<CGAL::Compact_container<CGAL::Triangulation_full_cell<TriangulationTraits,CGAL::No_full_cell_data,CGAL::Triangulation_ds_full_cell<TDS2,StoragePolicy>>,CGAL::Default,CGAL::Default,CGAL::Default>,false>,CGAL::Epick_d<CGAL::Dimension_tag<3>>,CGAL::TDS_full_cell_default_storage_policy>::neighbors_'
1> with
1> [
1> , Data_=MyData
1> ,
1> ]
1>C:\Program Files\CGAL-4.6.2\include\CGAL/Triangulation_ds_full_cell.h(71):
error C2955: 'CGAL::internal::S_or_D_array' : use of class template requires
template argument list
1> C:\Program
Files\CGAL-4.6.2\include\CGAL/internal/Static_or_dynamic_array.h(54) : see
declaration of 'CGAL::internal::S_or_D_array'
error C2027: use of undefined type 'CGAL::internal::S_or_D_array'
1> C:\Program
'Vertex_handle_const_iterator'
1>C:\Program
1>Files\CGAL-4.6.2\include\CGAL/Triangulation_ds_full_cell.h(71): error
C4430: missing type specifier - int assumed. Note: C++ does not support
Files\CGAL-4.6.2\include\CGAL/Triangulation_ds_full_cell.h(72): error C2146:
syntax error : missing ';' before identifier 'Vertex_handle_iterator'
1>C:\Program
1>Files\CGAL-4.6.2\include\CGAL/Triangulation_ds_full_cell.h(72): error
1>C4430: missing type specifier - int assumed. Note: C++ does not
1>support default-int
Thanks,
Daniel
- [cgal-discuss] Attaching Data to dD Delaunay Triangulation Vertices, Scherrer Daniel, 09/08/2015
- Re: [cgal-discuss] Attaching Data to dD Delaunay Triangulation Vertices, Clément Jamin, 09/08/2015
- RE: [cgal-discuss] Attaching Data to dD Delaunay Triangulation Vertices, Scherrer Daniel, 09/08/2015
