cgal-discuss - Re: [cgal-discuss] segfault in Monge_via_jet_fitting
  • To:
  • Subject: Re: [cgal-discuss] segfault in Monge_via_jet_fitting
  • Date: Thu, 17 Sep 2015 10:58:12 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-phdr: 9a23:seFhUBZ7L1HH/VVMZt1rmW//LSx+4OfEezUN459isYplN5qZpcm8bnLW6fgltlLVR4KTs6sC0LqK9fu5EjRRqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLsh7z0oMSYO1QArQH+SI0xBS3+lR/WuMgSjNkqAYcK4TyNnEF1ff9Lz3hjP1OZkkW0zM6x+Jl+73YY4Kp5pIYTGZn9Kq83RLgdADU9OH0u/+XqswPCRE2B/CgySGITxyFJBg/DpD77RJ7svizm/r5m2SydO4v5TKo9RDil849kRRjthTsdJjAw+33QkN02h6Ve9kHy7ydjypLZNdnGfMF1ebnQKIsX
Hello,
Using Lapack with CGAL is not officially supported anymore (and is not documented/tested). Is there a specific reason why you need to use Lapack?
Otherwise I would recommend you use Eigen ( http://eigen.tuxfamily.org/index.php?title=Main_Page ) which is also compatible with OSX and is officially supported (and tested) by CGAL.
Please let us know if you still have trouble when using Eigen,
Simon Giraudot, PhD
R&D Engineer
Geometry Factory - http://geometryfactory.com/
Le 16/09/2015 00:47, chrism a écrit :
Hi,
I am attempting to calculate the mean curvature on a Delaunay2D mesh. For
each face of the mesh, I create a set 18 surrounding points to use with
Monge_via_jet_fitting created as thus:
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Monge_via_jet_fitting<K> CGALMongeViaJet;
typedef CGALMongeViaJet::Monge_form CGALMongeForm;
I have installed LAPACK, am linking against LAPACK in my cmake, and have
enabled LAPACK in CGAL with
#define CGAL_LAPACK_ENABLED
If myPoints is the set of surrounding points of a face (including pts from
that face), I call monge via
std::vector<Point_3> pts;
pts.assign(myPoints.begin(),myPoints.end());
monge_form = monge_fit(pts.begin() , pts.end(), 4,4);
However monge_fit segfaults. I have tracked to l48 of
Linear_algebra_lapack.h
::dgelss(*m, *n, *nrhs, a, *lda, b, *ldb, s, *rcond, rank, info);
I have dumbed the M and Z matrix/vector to disk and matlab can obtain a
solution.
I am on OSX 10.9, CGAL and LAPACK installed from homebrew. Details on these
follows. I would appreciate any guidance on this issue. Thanks.
brew info cgal
cgal: stable 4.6.1 (bottled)
CGAL: Computational Geometry Algorithm Library
http://www.cgal.org/
/usr/local/Cellar/cgal/4.6.1 (2803 files, 34M) *
Built from source with: --with-lapack
https://github.com/Homebrew/homebrew/blob/master/Library/Formula/cgal.rb
==> Dependencies
Build: cmake ✔
Required: boost ✔, gmp ✔, mpfr ✔
==> Options
--c++11
Build using C++11 mode
--imaging
Build ImageIO and QT compoments of CGAL
--with-eigen3
Build with Eigen3 support
--with-lapack
Build with LAPACK support
brew info lapack
homebrew/dupes/lapack: stable 3.5.0 (bottled)
http://www.netlib.org/lapack/
This formula is keg-only.
OS X already provides this software and installing another version in
parallel can cause all kinds of trouble.
/usr/local/Cellar/lapack/3.5.0 (3851 files, 29M)
Poured from bottle
From: https://github.com/homebrew/homebrew-dupes/blob/master/lapack.rb
==> Dependencies
Build: cmake ✔
==> Caveats
This formula is keg-only, which means it was not symlinked into /usr/local.
Generally there are no consequences of this for you. If you build your
own software and it requires this formula, you'll need to add to your
build variables:
LDFLAGS: -L/usr/local/opt/lapack/lib
CPPFLAGS: -I/usr/local/opt/lapack/include
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/segfault-in-Monge-via-jet-fitting-tp4661142.html
