cgal-discuss - [cgal-discuss] Surface reconstruction
  • To:
  • Subject: [cgal-discuss] Surface reconstruction
  • Date: Thu, 1 Oct 2015 07:44:09 -0700 (PDT)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
  • Ironport-phdr: 9a23:PzWuMRTmf8CjwTBWa9EJtOVwZ9psv+yvbD5Q0YIujvd0So/mwa64YBON2/xhgRfzUJnB7Loc0qyN4/ymBzZLsc7JmUtBWaIPfidNsd8RkQ0kDZzNImzAB9muURYHGt9fXkRu5XCxPBsdMs//Y1rPvi/6tmZKSV3BPAZ4bt74BpTVx5zukbvip9uNOU4Y3HKUWvBbElaflU3prM4YgI9veO4a6yDihT92QdlQ3n5iPlmJnhzxtY+a9Z9n9DlM6bp6r5YTGZPTJPppCOUARHR9azh0t4XXskzIQgKLo3cdSW4LiQFgAg7f7Ri8UI2inDH9s79+3CiBJsS+GbM9QzOmv/ZDRxrhiSNBPDk8pjKEwvdshb5W9Uvy7yd0xJTZNdrNbPc=
Hi all,
I am a new user of CGAL. I would like to mesh and import, from a 3D point
cloud, a model.
Following the user manual, I decided to try the "Surface reconstruction
using" the given example.
I obtained the following message:
In file included from
/home/klissa/Desktop/data/data_CGAL/surface_rec_from_point.cpp:11:0:
/usr/local/include/CGAL/Poisson_reconstruction_function.h: In member
function ‘bool
CGAL::Poisson_reconstruction_function<Gt>::compute_implicit_function(bool)’:
/usr/local/include/CGAL/Poisson_reconstruction_function.h:537:13: error:
‘Eigen_solver_traits’ does not name a type
typedef
Eigen_solver_traits<Eigen::ConjugateGradient&lt;Eigen_sparse_symmetric_matrix&lt;double>::EigenType>
> Solver;
/usr/local/include/CGAL/Poisson_reconstruction_function.h:538:38: error:
‘Solver’ was not declared in this scope
return compute_implicit_function<Solver>(Solver(), smoother_hole_filling);
make[2]: ***
[CMakeFiles/surface_rec_from_point.dir/surface_rec_from_point.cpp.o] Error 1
make[1]: *** [CMakeFiles/surface_rec_from_point.dir/all] Error 2
make: *** [all] Error 2
I have seen other message about the same topic, but I couldn't solve mine.
I am running the last version of CGAL on Ubuntu 14.04.3 (I am not an expert
user!).
Can anyone help me?
Kind regards,
Carolina
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Surface-reconstruction-tp4661178.html
