- To: "" <>
- Subject: [cgal-discuss] parallel library
- Date: Sat, 3 Oct 2015 09:31:14 +0000
- Accept-language: en-US
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=Pass
- Ironport-phdr: 9a23:t/12mBRF8S9I+/DLTtgGoojtxNpsv+yvbD5Q0YIujvd0So/mwa64bByN2/xhgRfzUJnB7Loc0qyN4/ymBzFLuM3R+Fk5M7VyFDY9wf0MmAIhBMPXQWbaF9XNKxIAIcJZSVV+9Gu6O0UGUOz3ZlnVv2HgpWVKQka3CwN5K6zPF5LIiIzvjqbpq8GVPVgD3WHtKZpJbzyI7izp/vEMhoVjLqtjgjDomVBvP9ps+GVzOFiIlAz97MrjtLRq8iBXpu5zv5UYCfayLOwESukSBzsvNyU55dbgqALYZQqJ/HoVFGsM2FIcCAfM6FT2X4z6rzDhnut7wiiTe8PsG+MaQzOnuoJmRB/hlG89PiU5+W2fo8Z8gaZAqRisvVQrxoPYYIiJA+B3ZaPUcfsRRCxaQ8tDESFNH8WxYN1cXKI6Ie9Eotyl9BM1phykCFz0CQ==
- Spamdiagnosticmetadata: NSPM
- Spamdiagnosticoutput: 1:23
I’m using CGAL 4.3 on fedora 20 for 3d mesh segmentation but I cannot find library which support achieving the process by using GPU unit Is it exist? ,if there is a library tell me what it is , if not what is the other solution or alternative for achieve my task Thanks a lot |
- [cgal-discuss] parallel library, Medhat Rashad Abdelsaber, 10/03/2015
- Re: [cgal-discuss] parallel library, Sebastien Loriot (GeometryFactory), 10/05/2015
- Re: [cgal-discuss] parallel library, JuanLu, 10/05/2015
